kayakertom
Everything posted by kayakertom
For the rears, it is fairly easy and inexpensive to replace the shock cartridges. You take out the whole unit - no special tools and then disassemble. Don't even need a spring compressor. If they are really old, you may need to replace the hard rubber stops and maybe the plastic dust shields. Best to source these parts before you start.
Problem : Serious Hesitation Issue!
kayakertom replied to Steveman09's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If your fuel tank is original, it could have enough debris to clog your 6 month old fuel filter. Why run Bosch plugs? I've had problems with them after only a few hundred miles. -
Black electrical tape does a good job in hiding the auto trans indicators. I did an auto to d/r 5 speed trans swap and considered it too risky to mess more than I had to with the dash.
If you are still unable to open it, I can help on Sunday afternoon. I have the same year / model, so we can figure it out.
In October, it took me 5 trips to DEQ in Oregon to finally pass emissions with my 87 dl wagon. New plugs, cap, rotor and a fresh oil change helps. Can you do your own timing? Clean up the timing marks on the flywheel through the access area with a wire brush and use white-out to clearly mark the correct timing mark.
Would double check that the timing sprockets are correctly aligned, dump the Bosch plugs for NGK. Did you disable the vacuum advance when you did the timing?
Zeroing in on a vacuum leak...
kayakertom replied to kayakertom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Daeron: my plan is to tee in a vacuum gage to verify a leak. GD: It's SPFI and does idle up with the ac button depressed. -
OK, this was a new one for me - might help someone else. My '87 gl 3-door has been on the road for a few months but has had an intermittent idle problem that has baffled me. Started the car today and it idled fine; decided to cycle the ac on, let it run cold for about 5 minutes, hit defrost and the idle goes really low, rev it up and then cycle through heat, defrost, bilevel, ac, off and defrost boggs it down each time. Guess I'll be avoiding defrost and pulling the dash after it warms up.
This is serious damage that would be a challenge for almost everyone here to fix right - an impact violent enough to do the damage you describe will most likely require the services of a frame shop. Good luck...
One big MYTH is that the oil pumped from the oilfields all across the world originated from dinosaurs... If you think about it, it doesn't make sense. (How many barrels of oil from a dinosaur? How many barrels of oil of proven reserves? How many dinosaurs does that imply?) The oil comes originally from millions of years of microorganisms in the old oceans dying and dropping down to the seafloors. Lots of geological activity burying and compressing those deposits. Further evidence of this is the examination of exploratory drilling cores - you tend to find identifiable ocean- life micro fossils in those oil bearing shales. Mini-science lesson for the day.
I had a similar experience with a spfi and new headgaskets and it did turn out to be the intake manifold gaskets, like GD suggests. I would drain oil for a long time, drain coolant, replace the intake gaskets, replace just the oil, disconnect the fuel pump fuse, take out spark plugs and rotor and do a compression test.
Can you clarify what you are saying here? "checked plugs getting spark to the distributer cap only..thinking new distributer cap and rotor??"
https://www.1stsubaruparts.com/partscat.html Description Year MSRP Price Your Price PISTONS, Brat - 4 CYLINDER - 4 CYLINDER 84-87 $62.20 *** $44.78 ps: Is your town of Walsall the one outside of Birmingham in England? That's one of my grandmothers hometown.
Im about to replace HG any tips?
kayakertom replied to flyjum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Another thing: When you drop the exhaust manifold, put some plastic bags over the two manifold openings to avoid getting coolant down the pipes when the cylinder head is removed. -
First time: have a newspaper covered flat surface ready to put your removed parts on with several small containers for the fastners - keep the fastners with the parts you remove grouped together. Have a cleaning station set up - large shallow container with "Simple Green" or other grease dissolver, wire brush (small), old toothbrush, paintbrush and plenty of rags. Large mouth, shallow container to collect your coolant, funnel and another gallon container. You will also need an rtv sealant for the cam tower Tools needed: 10, 12, 14, 17 mm combo wrenches, metric socket set - deep ones are useful in several areas, breaker bar with 17mm and 22mm sockets, torque wrench, phillips and regular screwdriver, adjustable wrench, safety razer blade for scraping off old head gasket material, some fine wet/dry sandpaper, magnetic pick-up tool, mechanics mirror, grease for when you reinstall the lifters and rocker arms - holds the rockers from falling. The head bolts have a tightening sequence that you should follow. You should also replace the intake manifold gasket. Rotate the engine until the center of the three marks on the flywheel is at the pointer. Take your time and have fun. Don't curse too much if you are doing the drivers side and go to take the clutch fan off. -
Alec, On that trans there are 3 openings for switches, I know you found one that lacked a switch for the previous leak source - just checking that all three openings are blocked.
Heater fan improvment?
kayakertom replied to -mountain-goat-'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
When I lived in Fairbanks, I supplemented my heater / defroster in my saab 99 with one of those portable electrical ones that plug into the cigarette lighter. -
CV Joint - boot keeps ripping
kayakertom replied to washakie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The 87 dl wagon that I have came with that problem and adding a heat shield between the cat and inner boot solved the problem. My shield is mounted to the heat pipe flange (carbed engine) and is just a piece of duct metal with several small bends to add max clearance around the boot. Keeps the boot from being cooked and cracked. -
Can't dislodge driver side cam case...
kayakertom replied to PonchoCatalina's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Correction: There is the water pump pipe bracket with the ground connection that needs to be disconnected from the top of the cam tower. -
Removing an EA82 transmission: Drop it out?
kayakertom replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Drain the trans fluid before removing, otherwise you will have a mess. -
Good article on cylinder heads and engine blocks: http://www.aa1car.com/library/ar996.htm I've just experienced the failure at cold temperature of a newly installed head gasket and a probably not flat cylinder head - would weep/drip coolant until warmed up. Will be installing a "Stone" head gasket with a fresh rebuilt cylinder head. The "Stone" head gasket is the type carried by Discount Import Parts in Beaverton - has a nice contoured rubber seal integrated with the head gasket and better matches the coolant passageways than does FelPro.
