Gurm70
Everything posted by Gurm70
OCEI77, the fuel pump was changed less than a month ago with an aftermarket bought from Autozone. Not saying it cannot be bad. At the time the car would not run and the pump solved the issue. At that time I could cycle the ignition and would get a short pulse of power on the blue wire with yellow stripe at the pump. Now when I cycle I get no power there and no fuel at the filter which led me to believe there has to be a power interruption. When I get home I will check the ignition fuse. I was busy looking looking for a fuse in the fuel system and then the relay to see if I was getting power there that I did not check ignition. It The car will crank and will fire on starter fluid. Thanks for the link to manuals and I will check them out tonight when I get back from the office.
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
Someone please tell me where to find the fuel pump relay in this car. The aftermarket somewhat of a service manual I bought says behind the fuse panel under the dash left side. I have big hands, I have found the lower bolt/nut for the fuse panel mount and there must be one up higher but there are so many other boxes and harnesses that I cannot get my paws in there. I cannot see anything through all the boxes. Do I need to disconnect everything to get to the relay?
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
Another update. From another post I have learned that losing my cranking is definitely associated with anti-theft and lack of voltage triggering the system.
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
Guys I am new to Subaru and posted a no start problem today in another post. This post has helped me understand what has been happening with my intermittent no power to the starter. I did not know that low voltage on its own would trigger the anti-theft. On a couple of occasions I have been trying to troubleshoot the car and it just stopped being able to crank. My daughter who owns the car and only calls when it is not working filled me in this afternoon when I asked. Above it said to unhook the battery but the way my daughter just showed me did not require such. I am going to explain here and on my own post and it is suddenly clear what has happened. As I was cranking the car I could hear the battery was losing voltage and cranking was fading. I do not know if this is intentional on Subaru's part but I imagine it does help protect components. The anti-theft kicked in and cranking ceased. In frustration I was shutting every up and stopped to get old service records from the glove box. It was then that I heard the relay cycling off and on. I was able to get it pause when I triggered a couple of things and then it would restart. I saw the red light flashing on the dash but I though that was normal as I had already looked the doors even though i had not closed. As I started to walk away I saw the parking lights were flashing. After a bit they stopped. I asked my daughter when she got here.m So the way that my daughter says she was told to do is it. To lock the door from the outside with the key and then unlock. Open the door and with the key in the on position hold the black button under the left hand edge of the dash down by your knee. She held the button with the key on for the count of twenty and the light on the dash reset and she was able to turn the car over. She did say that it is strange because sometimes when it happens and she hold the button after the twenty count the the door lock cycle 3 times and other times she just see the light go out. Either way it solved the my ghost issue. Of course before you try any of this you need to make sure that battery voltage is back to normal.
My daughter has confirmed that the lights are associated with the anit-theft. I now know how to reset that system and the car cranks now. Does anyone know if that system kicked in if you cranked a certain number of times without an engine start occurring.
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
So I am new here today and I will start by saying I have good mechanical skills and I hate cars. I got married in December and with that came a step-daughter with 1998 outback approaching 300K(she bought it about a year ago). I know nothing about Subaru. I have replaced the clutch and associated hardware in the car. I apologize for the length of this post She called me a little over a month ago to rescue her from a parking lot. I found that the alternator on her car was not charging. I charged her up and ordered a new alternator. She drove the car for two days charging the battery and then taking the short drive to work. On the second day when she was going to bring me the car she called to say it would not start. I drove to her and installed the alternator while charging the battery. After installing the alternator I tried to crank the car over, it cranked but would not start. I checked the spark and it was good, so I started checking fuel, no books, no drawings. I tried to hear the fuel pump but nothing. Now is where it gets weird to me. I stopped to remove a fuel line and check for any sign of pressure or flow and then tried to crank again, nothing....I load checked the battery and it was solid. I went looking for fuses and found none. Did not know where to find fuel relay but that did not matter as the electrical was not getting to the starter solenoid. As the sun was setting I decided to have it towed to my house. The next morning before I left for work I tried it and it started right up. I left a message for the daughter to try it later and she did and it started. She drove it around for a day and the next day she went out and it did nothing again, no crank. That night it cranked but did not start. I found online some information and went in search of the fuel pump. Testing showed voltage on the blue/yellow wire, so I ordered a fuel pump. Her brother and a mechanic friend installed the fuel pump while I was away and it ran fine. 3-4 days later, turn the key no crank. Her mechanic friend said it needed a starter, I disagreed and checked the starter with a remote start switch. All fine there. Next morning it cranked and she drove the car for a couple of weeks with no problem. Monday of this week she drove the car home from work said she was having what sounded like fuel issues to me. She tried to restart it and it would not start. I checked the blue/yellow wire thinking the new pump might be crap and found no voltage. Went and bought a Haynes and looked for answers. I now know where the fuel relay is but i have not dug it out yet as I have not had time. Went out this afternoon and wanted to recheck voltage to pump. Had my wife depress the clutch and hold it down I had her crank it a couple of times. I had her hold the clutch to the floor to try to eliminate a neutral start switch. Without ever letting off the clutch, after 6-7 times cranking, tried to crank again and nothing there. I had it hooked to a battery charger the whole time. Any of this make sense to any of you dear readers? I could use some advice, I noticed when I started to dig for the fuel relay that Subaru's have lots of wires and switch and boxes. Last item. As I was closing up the car I heard a relay clicking on and off. It was flashing the four ways but at half speed of what the 4 way button flashes them. I move the blinker control and it stopped for about 10 second and started again. The daughter has mentioned that sometimes when she parks the car the lights do strange things. Would this have anything to do with the anti theft device? I locked the car up and retreated up to my home office, they were still flashing and then just stopped. Help please
- 11 replies
- fuel
- electrical
(and 1 more)
Tagged with:
