Jeffg8912
Everything posted by Jeffg8912
  1. Hitachi distributor and I've been a ND NGK guy for a long time Started right up first try thank you so much
  2. Is there a brand or a specific type I should be looking for I have a tube of permatex #2 non hardening form a gasket but it makes mention of applying it in a thin film not so much as a bead
  3. Thank you so much I have the chilton and the Haynes manual and The information in one manual kind of conflicts that information in the other I just wanted to hear it from someone who knew thank you Also the manual says to use RTV sealant when attaching the camshaft housing is there anything special I should use other then you're basic blue RTV when I took it apart the sealant that was in there was gray and a little firmer and had some leaks is there something I might use that would do a little better Thank you J
  4. I have an 86 GL station wagon with an E 82 motor 1.8L If the valves are replaced is there any adjustment necessary
