3
Everything posted by franbev
clutch cable keeps seizing/snapping
franbev replied to Geluso's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What's the Subaru OEM part number for the clutch cable on a 1985 Brat? -
Or should I say smash-up. https://www.craigslist.org/about/best/orl/5948013632.html
On a Brat the ride height is adjustable front and rear. In the front, the lower spring perch has adjusters. In the rear, there is a 19mm bolt on the center of the torsion bar to raise and lower the rear end.
I got a good passenger seat for my '85 Brat GL (thanks Dan Hardy). I plan on putting it in place of my worn out drivers seat. I see how the seats are attached to the adjuster rails and that should be easy. My question is can I take the seat back tilting mechanism off of the drivers seat and put it on the replacement passenger seat? Right now the back seat adjuster is on the right side of the seat going in and I'd prefer it to be on the left side when it is installed.
How tough is it to convert an EA-81 with a carb to propane? What problems would you expect? Any kits available? What advantages are there?
Can't keep idle down on 84 GL 1.8 with Hitachi
franbev replied to markjs_pnw's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks much, can the Muir book still be bought? -
Where can I find suberdaves site? -
Can you just swap the seat cushions between frames?
Can't you just exchange the seats frame and all? I'm told there's some switching of parts like seat belt retainers but it's doable.
The ad refers to "simulated oversize rear tires" as one of the enhancements made. They do look cool though.
https://hartford.craigslist.org/cto/d/wethersfield-1984-subaru-brat/6950451886.html
No side steps either.
https://bringatrailer.com/listing/1986-subaru-brat-3/
How does it work on the black plastic bumpers?
Thanks Aussies! I was able to gently pry apart the lens from the housing. It must have been on there for a long time. After pulling the bulb I'm pretty sure that's the problem based on it's cloudy grey appearance.
Recently while driving my '85 Brat GL I got a warning light pop on stating that a brake light was out. I never knew that this Brat even had such a warning light. Anyhow, I established that the passenger side brake light was out, took off the tail light assembly to find three bulb sockets backsides. Knowing it was the middle one I tried to get it to come free from the housing. No luck. I didn't want to break anything. I don't see a way to separate the lens from the housing to get access to the bulb from the front. Any advise?
Beauty rings for wagon wheels
franbev replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just remember that the rings will really gouge up the Jackman wheels when installed. -
84 brat EA81 valve tapping
franbev replied to StallonePanerai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I always add a zinc additive with my fresh oil in my '85 Brat. I believe the EA-81 engine needs that. Todays oil doesn't have a zinc component like oil sold in the 80's -
Vintage plaid interior photos wanted
franbev replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you switching from a 4 headlight grille to a 2 headlight one?
- 51 replies
- 1
- brat
- cyclops brat wiring
(and 1 more)
Tagged with:
https://bringatrailer.com/listing/1978-subaru-brat/
Old School Subies and Synthetic Lubricants
franbev replied to Crazyeights's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't EA-81engines need zinc in the oil? Since zinc is no longer an additive in "todays" oil I add it separately.
