vtwinjunkie last won the day on May 4 2016
vtwinjunkie had the most liked content!
Gender
Not Telling
Location
Va
Referral
google
Biography
Long time auto/motorcycle enthusiast.
Subaru Ambassador! -
Vehicles
2016 wrx, 2005 legacy outback,1996 Legacy
Recent Profile Visitors
835 profile views
vtwinjunkie's Achievements
USMB is life! (4/11)
8
So I flushed the trans and added limited slip additive to it. no more bind! Perhaps it wasnt very bad to begin with...not sure but its driving great now. A question about the fwd switch....This is something I would be interested in doing....kinda for fun but also to see if it would save gas! Got a link to the mod?
All 4 tires are new when I picked it up. Not sure if anything was swapped but highly doubtful since previous owners had it for 10+ years and never mentioned it (they are very trustworthy so I feel like they would remember that). I actually did the trans drain and fill and added limited slip additive to it and it completely went away after 20 or so miles!!!
Thanks, outback and legacy are both 2005 , both auto 4 spd, and both 2.5i so I just assumed they were the same trans. That is great advice, thank you. I have tried all movements you have described. it definitely feels more steering related rather than being held back. no noises (at least relating to this that I can tell). It does have a noise going over bumps which I think could also be strut related (maybe the top hats) but Ill get to that after the steering issue. The issue only happens at just shy of full lock and clears up soon after on each side. I diddnt actually take off the cv boots to inspect them off the vehicle (turning in all directions and all angles to check for binding). I guess I will do that as well once I pull the struts next week to inspect the assembly (Car had strut work done before I bought it).
I thought more about this. I cant seem to distinguish it though....I tried to lube up the steering column real well and it didn't change a thing. The more I drive it and try to diagnose......Im wondering if a bent tie rod would cause it? It seems to bring the idle down when it catches...I am wondering if it is an issue with the power steering rack...
This 100%. My 2005 outback has 120k miles on the clock. Purchased with 97k miles 3 years ago it has been reliable and trouble free aside from general maintenance. The head gaskets are seeping ever so slightly but no oil ever makes it to the ground and it doesn't burn a drop (that I can notice) My 2005 legacy has 170k on the clock. Purchased a few weeks ago and the underside of the engine looks the same as my outback hahaha. I haven't had it long enough to monitor the leak yet but it seems to be doing ok as well. I may do the head gaskets on one and not the other and just see how long it goes with constant monitoring but monitoring seems to be the key. As long as the engine has the oil it needs to lubricate itself it will just keep going (along with fuel compression and spark)...
