Phizinza
    2
Everything posted by Phizinza
  1. I still don't understand why you would drill the wheels when drilling the hubs is easy as well and is much neater.
  2. http://offroadingsubarus.com/driveshaft_axle_removal.html
  3. In Aus they only came 2wd. And if you want to put 4wd in without a lift I would highly recommend getting an auto (more trans tunnel room, less cutting)
  4. I do like those wheels... I'm so tempted to do a road going awd leone but ....:-\
  5. Yeah, I'm on my third set of struts in the race wagon. This time though I've cut them up and put insert struts inside, this will double the strength I am hoping. Also gone from 125mm travel to 210mm travel. I reckon I'm gonna bust some CV's come two weeks from now (race day).
  6. When I jumped the race wagon it bent the bottom of the struts and gave negative camber.
  7. Adjusting the struts up can stop the rubbing but as soon as you flex it offroad it will rub again. Lifting puts blocks above the struts and so the wheel cannot travel far enough up to rub again. So you need a body lift kit. But I agree with monstaru.. Search.......
  8. Those old fuel lines running from back to front get a little crumy and there's no filter between them and the carby. Probably shook it up with the bumps and got crap in the jets. Just feel happy that this didn't happen http://offroadingsubarus.com/images/lrc08_subaru11.jpg
  9. Pull it out, fill it with silicone, let it set, put it back in.
  10. +1, wild cards are your friend. But I also agree google is much better and the site: function in google works great.
  11. I agree with this. If I were a tire business owner I wouldn't touch anything like that because the liability you have wouldn't be covered by your insurance and you'd be in s*** if anything happened
  12. So they appear like an open diff when you turn on side of them? So this rear diff VLSD type isn't like the centre VLSD's Subaru's have because they don't have a preload tension?
  13. Those extra pictures in that link at the bottom of Brian's post make it look morel ike a clutch lsd? Many plates
  14. Nothing crazy like Block, but I don't drive a $500k car. Many more pictures at http://offroadingsubarus.com/lrc08.html
  15. If you drive easy with 5 to 10 psi in the tires then it would probably do alright. Biggest issue I think you will have is over heating. EA82's hate sand as it gives them extended hard work. I've only driven on beaches and sand dunes next to beaches so I dunno if they differ to inland dunes. But I've driven on some soft beaches even my EJ22 5sp Brat with 27x8.5R14 at 10psi had trouble with. Just gotta know when to stop I guess. Those videos: looks like that sands pretty hard vs what I'm used too.
  16. No, just wanting to jack it up some more as after all the jumps and mud the thing sags a bit. Ended up welding some more onto the end of the adjuster bolt as I had no luck getting those splines apart (way too much rust probably). I stuck about 15mm of some random bolt on the end of the adjuster and gained a little more then 50mm extra height. It was at the point where fully adjusted up sat as the usual fully adjusted down position. Poor cars taking a beating from all these jumps.
  17. LSD's can be Viscus LSD, Clutch LSD, Mechanical LSD or Electronic LSD. So comparing a LSD to VLSD in my mind makes no sense as a LSD can be a VLSD.
  18. Viscous. I think between the side gears and the carrier there are viscous plates. Basically little oil pumps that create high pressure oil between two surfaces to gain friction.
  19. Any trick to this? I can't get the splines apart. Taken the swing arm bolts out, and the 12mm hex pin. But no amount of bashing is freeing it.
  20. Ok, so if that is a VLSD, then can I have a picture of a open diff? Or could you answer me this, are the side gears the same?
  21. Cheers mate, found a couple of pictures. In the bottom of this thread here http://forums.nasioc.com/forums/showthread.php?t=1769174&highlight=R160 there are some pictures. I have a question if anyone is keen to answer. The pin has a cut out on just one side, why is this? To clear the stub?
  22. Sorry I am too busy to buy, pack and ship gearboxes. They sell for about $800AUD over here and shipping at a guess would be $200 a box. You might find someone interested in shipping one over for you on OffroadingSubarus.com or AUSubarus.com. I think they were out of 98 to 02 forester but could be the later ones or might be both.
  23. Hi, I need a picture of the inside of a Newer Forester or Outback R160 diff (the ones which clip in stubs not bolt on stubs). Cheers, Thomas
