Phizinza
    2
Everything posted by Phizinza
  1. I'm going to be one of those pesky people who says.... Been posted lots of times, and is this really the place to post a ATV with a EJ20t? Still.. it's cool. If you like death on a stick that is...
  2. Phizinza
    Video!
    The power is yummy to say the least
  3. Phizinza
    Video!
    This forum seems a little slow lately.. So I'll try and help out to get it go'in... http://video.google.com.au/videoplay?docid=1056087957420582739 http://offroadingsubarus.com/downloads/hill_climb_april07.avi Do you like the title? I thought it might get some attention?
  4. Ebay sometimes has cheap brand new ones. Then get someone to weld it in.. Expencive for an old roo, but if you want legal you gotta pay.
  5. I would go to toyota as well (or what ever brand had a truck I liked) if I could have two cars. The reason I pick Subaru and stay Subaru is I can only afford to have one car. And I like going fast onroad. Subaru's are (to my knowledge) the best cross-over vehicle ever made. When I get a full time job, I'll be 4x4in in a truck and on the road in something else (might even still be a Subaru.) It's just it cost so damn much to register and insure a car in Australia My new Subaru forum has an offroad section for any cars and trucks plus a section for talk on yota's and what ever
  6. Red line doesn't mean much.. It's just a "safty" warning. I took my EA81dc to 8K, and it's still happy.... well it needs a rebuild, but still for a 250,000km motor.. Maybe you get less predestination with better fuel control?
  7. I'm still Subie'in myself but, I hope this is ok... My brother bought this to replace his 83 wagon a couple of weeks back. It's an 84 2.4L Diesel 4Runner, solid front axle. It has 2.5" suspension lift, snorkle, and a few other things Fitted another bullbar, and a winch. His looking to get new tires soon. Two lockers are on their way from the states. He also put the CB in it and is going to be fitting some spot lights, maybe his 220mm Bull lamps...
  8. Any brand, any kind. I've never had a problem with any plugs I've had in my EA81.. That said, I'm putting NGK's in my EJ22 because they were cheaper then bosch.
  9. This is in my Brat, but I have the EJ22 plus the trans casing and clutch from the Leg (Liberty.) So I only have to look at it being a push type, ok, sweet. I want to replace mine because I believe either one of the fingers is broken, the flywheel warped or the plate is bent, maybe a spring broken. Well anyway basically it's getting clutch wobble and the thrust bearing is squeaking it's head off which is getting on my nerve, so I want a whole new clutch and I'm going to get my flywheel balanced and lightened I reckon.
  10. Well my brothers wagon cost him $250... So two coats with no sanding done his quite alright He done a good job at matching the paint color (he works at the hardware store so he mixed it himself.)
  11. The ball joint stays EA81, you just swap in the EA82 cup. Most of the EA82 shafts have a CV on the outter, so if you get the cups from the diff side (which I think fit on both sides of the EA81 shaft) then you get more extension out of them because the EA82 cups are longer.
  12. I feel sorry for you guys... The biggest bit of rust on my car is about 4cm long and 1cm high, and theres only 2 other spots that are worth talking about anyhow...
  13. You think thats bad, my brother used a paint roller on his 83 wagon :-p Doesn't look to bad really, just a little textured and not shiny... I think I'll do my hood and roof properly, I know a panel beater.
  14. Probably a bit late. But when I put the new ignition switch in my Brat it doesn't like to start the car, goes to ignition then when turned to start it only works 1 out of 10 times. I've hooked up a push button start now so I just turn the key to ignition and hold the button down. Works good.
  15. EZ30, doesn't that have a built in immobilizer that is REALLY hardto by pass and won't work unless it sits in it's original body or something weird like that? Although it does use cam chains :cool: ER27 uses the same gearbox pattern, plus the same mounts I believe. So you don't really need to modify anything to put it in except the radiator. Very easy. But you better have a FT4WD box or else that thing is going to be a FWD burnout king.
  16. The wiring looks scary, and when your doing it its' scary. But it isn't really hard. I know I'm good with wires and all that (kinda had a thing for electronics a couple of years back) but it only took probably a total of 16 hours to remove the harness and cut it done. Add another 6 hours for looking all over the net for things I needed to know and asking people questions. I look forward to doing my next loom cut down as maybe I'll be able to do a good write up on it. I can see however why people want to carb. It simplifies things to no end. None of these silly codes popping up all the time. But the power throughout the power band on the EFI 22 is just awesome. I don't think it would be very easy at all to get a carb to do the same thing.
  17. What sort of clutch upgrade can I do for an early 90's leg with a 2.2? Would a WRX clutch fit, and would it be any better? What years are compatible? Thanks.
  18. http://offroadingsubarus.com/downloads.html All oldies, but some new ones should be coming soon.
  19. Those front tires look beefy for low profiles... Looks pretty mean. Your not going to have a problem with the law and the tires sticking out where you are are you? Just a thought.
  20. possibly get a fork lift radiator as these are square and boxy with like 9 or 11 cores. Might fit behind one of the lights? Just a thought
  21. So vented EA82 front brakes are bigger then vented EA81 front brakes? I know the solid ones are smaller but never compared vented with vented. Interesting.
  22. Some EA81's (Brats, Brumby's, etc) did. If you want to put power steering in a Brumby you will need an EA81 P/S rack and pump. Although if you use an EA82 or EJ you can use their pumps. Even in RHD vehicles I think you can fit the pipes using either the EJ or EA ones.
