ThoR294
Location
Flemington, NJ
Biography
Auto mechanic turned IT Guy. I fix everyone's PCs and Cars. Barely time to fix my own. Bought my GF a 98 subaru for the winter! My first scubaru
Vehicles
1998 Subaru Legacy L Wagon AWD 2.2L 4AT
ThoR294's Achievements
Member (2/11)
4
Oops . The first flush made it sooo much better. Before it binded REALLY bad when I cut the wheel like 1/8th of a turn. I couldn't even drive the car. I had put it in FWD mode to drive it. After the first drain/fill, I am now able to drive it in AWD mode. I can feel the shudder on most 90 degree turns, but it is no where near as bad. I will try a few more drain and fills and try more posi additive. Good news on that I can rebuild just the clutch packs without re-doing the whole trans. Any recommendations on where to get the parts/write ups on how to do it?
Welp heres an update. The grinding noise out of the right rear was the backing plate. The bottom was rusted and hitting the rotor. I smashed some of it out and cut some of it away. It is mostly gone now. It is KIND OF there, but gone. Bearings are fine. Put 4 wheels and 4 new tires on it. I can now safely go over 40MPH lol. I did a trans service, the fluid was sooooooooooo brown. I put 4 quarts in like a moron, so it was overfilled, and I added 3OZ of GM posi additive with it (spoke with a seasoned scubaru tech, he said he does it all the time to cure it). I drained it down till it was properly filled. The shuddering has toned down A LOT. It is only there at extreme turns. So maybe keep flushing it?
Fixed right rear caliper, replaced rear brakes. Found left rear tire has a flat spot. Could maybe cause the "torque binding?" Its bad like can't even do over 55 lol (vibration from tire). Also found the bottom parking shoe spring on right side is hitting abs wheel? It hits hard when making a right but doesn't hit when making a left. Bad bearing?
Whoopdie do for my freaking Subaru!
ThoR294 replied to ThoR294's topic in Meet n' Greet. Your USMB Welcome Center
I had an 86 vf500 interceptor as well haha. Yeah Hazelton has many Subaru's!
