thedoctor
Everything posted by thedoctor
Rear Main Seal Question
thedoctor replied to thedoctor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks, man. -
I have an 83 dl front wheel drive and I'm getting ready to do the clutch this weekend. I have a spare engine off 84 GL 4WD. Can I/ should I use the flywheel from the 84 GL, which takes a bigger clutch and use it on my dl. Is this doable or even desirable. I pulled the 84 flywheel for resurfacing tomorrow, but I won't do that if it's not a good idea to go with the bigger clutch. If I stay with my present flywheel, I might not be able to have it resurfaced. How important is that?
Yes, that is what I just found out. My spare EA81 came off an 84 GL 4WD and I wanted to use that flywheel on my EA81 DL FWD, which I drive every day. I got a clutch kit today and it is the smaller one, a little less than 8 inches. Can I swap these and put the bigger clutch in my car? I was planning to have the 84 GL flywheel resurfaced in the morning. (Should it be balanced?) This is pretty new stuff for me so I have some pretty basic questions.
:-\ Please help. I just picked up a rear seal for EA81 '83 dl. It was about twice the size of the front seal, which I have had but have not installed. I thought I heard they were both the same. The parts guy (not a Subaru parts dept) thought they were the same on 4WD but different on FWD vehicles like mine. There was an atmosphere of "I really don't know" about the whole thing. I want to have the right parts before heading into my clutch job weekend. This rear seal is approx 3 " in diameter and the front seal was maybe 1 1/2.
Can anyone tell me if a flywheel off an 84 gl is the same as a flywheel on my 83 dl. They are both EA81 engines. I am getting ready to do a clutch job and it would help if I could take the flywheel off the engine sitting in the shop and have it surfaced, but I want to make sure it will fit my engine. :-\
The physics of tire size
Thanks one and all. Very helpful. -
I have an 83 dl daily driver. Looking for recommendations on new tires. Stock size: 155SR13. Knowing that stock is not always best... what size tire is best for economy vs performance? I'm looking for the physics answer. For example, will a larger tire give me better economy on the highway, but ruin my clutch in stop and go driving? Please help me think this through. And please share thoughts about best brands for durability, etc. Thanks
A friend was following me home and told me my left rear wheel seemed to be angled in. I looked at the tread on that tire and the outside edge is wearing much more than the rest of the tire. What could be the cause of this and how do I fix it?
Gas tank rust????????????
thedoctor replied to BattleAxeT6's topic in Old Gen.: 80's GL/DL/XT/Loyales...
About the carb, I hope it isn't a Carter/Weber. I have one and got a quote from the factory on a rebuild kit: $210, not for a rebuilt carb, for the kit. So far I'm keeping it alive with Seafoam and chevron techron every now and then. Ether is handy for real cold mornings. -
The varying shaft size gives me some hope. First thing in the morning, I will double check. It is possible that the inner joint has in and out play that I had not taken into consideration.
I just pulled my left axle. Bad CVJ. I have a rebuilt axle which seems to be about an inch longer than the old one and with a bit thinner shaft. The joints themselves look the same. I am assuming the parts store gave me the wrong part. Am I correct in thinking these should be identical? This is probably a stupid question, but that's how I learn.
I definitely have an O2 sensor because I replaced it trying to get my ECS light to go off. Other than that, torxx, you're right that I need to get familiar with my car. I learn a little more every day (some more than others). It will take me a few days to digest the info in this thread.
Where can I find the special socket(s) to torque the head bolts on an EA81. I am also in the market for the valve adjusting tool. Are they available here? Are they really needed or are there common work-arounds?
OK, let me re-word the question. Not that I would disconnect anything illegally, but for academic reasons only, what extra equipment would be on an 83 dl, which, if removed, would simplify the operation of the vehicle? O2 sensor? Certainly the catalytic converter (mine is new so I'm really not going to remove it) Someone on this message board told me to disconnect my "computer crap" behing the steering column. I didn't, but I'd like to know if it is needed. Any thoughts?
Would anyone out there say Hitachi over Weber? I can live with my Carter-Weber for a while yet. Is the consensus that, as long as I am going to be swapping intake manifolds, it would be better to get a Weber rather than to rebuild the Hitachi?
What's this? This is the first anti-weber talk I've heard. Of course I am totally wet behind the ears. Is there widespread agreement about this? I was advised quite strongly to get rid of my undersized Carter-Weber and get a Weber. My whole reason for beginning this search was a no start condition. The last thing I want is a hard starting carb.
I'm in PA with an 83 dl. We have emissions testing: the gas cap - that's it. In the mean time I am looking to simplify this EA81 to the maximum extent possible. I would love to disconnect every possible device that does not contribute to either efficiency or performance, with the emphasis on the former. What can I get rid of and exactly how? Right now I have a Carter-Weber carb, but I just bought a spare engine with the Hitachi. I am looking for a Weber carb to use with the Hitachi intake manifold.
Wheels not on the wheel page
thedoctor replied to Ross's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where IS the wheel page? I Wheely want to see it. -
Are radiators different in A/C cars?
Come on you guys. A friend of mine is telling me these radiators are somehow different even though they look identical. He doesn't know soobs though. He got this idea somewhere that radiators off of A/C cars are double or something. My dl with ac radiator has two fans, other than that it looks the same. -
Will a radiator out of an 84 GL no A/C work in an 83 DL with A/C? Aside from the two fans I mean. Is there any internal differences about the radiator with A/C?
What is that clicking sound?
Just an update on my incredibly frustrating:banghead: no start in cold weather. I was faced with a carb rebuild on a Carter-Weber --who would even want to do that-- so I tried Chevron Techron Concentrate -- and so far I've had immediate starts, that surging at cruising speed is gone, and the dieseling stopped. I'm ready for some single digit nights now. Thanks for the great information. -
Just an update on my incredibly frustrating:banghead: no start in cold weather. I was faced with a carb rebuild on a Carter-Weber --who would even want to do that-- so I tried Chevron Techron Concentrate -- and so far I've had immediate starts, that surging at cruising speed is gone, and the dieseling stopped. I'm ready for some single digit nights now. Thanks for the great information. PS I do have another engine lined up, EA81 with 116K on it. It has a Hitachi carb. I'm still thinking of picking it up to play with (I can get it for $50 -80, depending on the deal) What do you think?
I found an EA81 in an 84 4WD wagon. There is a number on the block EA81 41267 I am wondering if this will fit in my 83 dl which is a 1.8 liter. Can you tell from the number what size this engine is?
Accell Spark plug wires
thedoctor replied to LoyaleFan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is there a good web site that handles MSD, Magnecor, Accell?
