lrgvanman
Everything posted by lrgvanman
  1. Hi, all. I am looking for a replacement corner light bulb socket with pigtail for my 1984 GL wagon. Anyone have a lead? Thanks in advance. - Larry
  2. I never did get them loose and could not find the lever either. The seat covers already had the opening to slip the headrests through. Problem partially solved.
  3. I'm trying to find at least two exterior door handles for a 1984 Subaru GL wagon. Thanks in advance.
  4. Do you still have any door handles for an '84 GL wagon? Tweakers have broken two. Looking for RR.
  5. Actually the speedo is okay and spot on with my Tom-Tom and the GPS black box is wrong. Thanks for all your help and suggestions. I took the speed head out of the "new to me" cluster and put it into the original cluster and all is good now.
  6. I dug into it. I took the original and carefully pulled the "glass" then pulled the black "separator". Next, I removed the two screws that secure the head and did the same with the donor, eventually replacing the drier head into the original assembly in reverse order. All works now but reads 5 mph slower against a GPS Speedo. Tomorrow's another day...
  7. Well, to start off, I attempted screwing in the cable into the trans and had to carefully modify the end of the cable (shorten) by 1/8 inch because the seal was apparently thicker that the original and the cable would not mate. I finally got it into the trans and out of kicks, reassembled and the test drive showed my fear that the speedo is useless and still faulty. So, I put the replacement cluster in and its speedo works but I cannot get half the lights to work and the fuel and the voltmeter are useless. So, does anyone know, how does this cluster safely disassemble? I figure while I am wasting time with futility, I might get lucky at random by cleaning out the original speedo. I mean, what the hell, why not since these things are so scarce that I cannot find yet another replacement? Thanks in advance for any info.
  8. 22mm 1/2" drive socket on bolt with end of 3-foot breaker bar on driver's side ground (if right hand drive) then bump starter. Make sure to pull the coil wire FIRST! I foolishly misstated that. It should apply to LEFT hand and not RIGHT hand drive. Otherwise correct. Sorry.
  9. 22mm 1/2" drive socket on bolt with end of 3-foot breaker bar on driver's side ground (if left hand drive) then bump starter. Make sure to pull the coil wire FIRST!
  10. As far as that oil seal in the transmission end, whereabouts is it and what does it look like? I am going to search for a transmission parts list after this post. Thanks for any information anyone can furnish. April 24; So, I have received a new cable and when I pulled the old cable from the trans, I saw the dreaded oil. The seal has breached and I have found that the new cable also replaces that seal. Now, how to insert and screw in the cable end as it seems not to be going in all the way. I realigned the slot with the cable drive and cannot get the cable to mate the "screw" with the hole. Hmmm... Going to the library to see if they have a definitive picture of the hole, its angle, etc. I'm wondering if I shouldn't just put a plug in the hole and use GPS!
  11. Thank you, Steptoe. I haven't done it yet but likely will pretty soon.
  12. What a drag. Got a used cluster but will check cable first for oil migration. I'm about to find out. At 66, I'm not so limber anymore but my wallet is small so here goes! Is the speedo end clipped in? Mine reads 80 mph at actual 30 mph.
  13. I'm about to find out. At 66, I'm not so limber anymore but my wallet is small so here goes!
  14. Thanks, GD. Tell me it ain't so... I tried to take out the instrument panel once and gave up. Guessing that's on the agenda again, along with a new cable?
  15. I found this and I am going to check it out and if I can, I will post the results. Gotta lot going on... https://www.techsupportforum.com/threads/speedometer-reading-off.181997/
  16. 1984 Subaru speedometer has gone awry! Reading 80+MPH while going 30MPH in actuality! Speedo hub at fault?
  17. I would take the remnants down to a parts house and see if someone can match 'em up. I have done it that way.
  18. I still have the replacement sitting in a box and I don't know the answers to your questions. I know that the cat will need to be lowered and the hardest part will be realigning, regarding the outer tie rod end reinstalls.
  19. I am in search of new rear inner and outer axle boot kits for a 1984 Subaru GL 4x4 Wagon, non-turbo ea81. Does anyone have a lead? I'd be grateful, squared. I want to service my axles but need boots as one is ripped and no grease is escaping, suggesting that it's DRY! Thanks in advance!
  20. Funny how this very same thing happened to the front crank seal of mine.
