Rattle wagon
Everything posted by Rattle wagon
  1. HELLA has H-4's for the outside and H-1's for the inside about 50.00 a peice also a 4-lamp wiring harness with relays from A.P.C also 50.00 I have this set up on my 79' wagon and its very bright!
  2. Hello I would be interested in your parts I have a 78' GF that needs a fuel tank sender and probably alot I can't think of right off!
  3. It looks alot like my 78' coupe trans mount only smaller, Has two short studs to bolt it to the crossmember and a sleeve for the bolt that goes through the bracket off the rear of the transmission, sleeve is suspended in the rubber.
  4. My coupe is in dire need of a new rear transmission mount its torn apart and I've already used some rubber like epoxy and it tore again, does anyone have any ideas?
  5. Hey Scott how much to lift an old wagon or brat?
  6. I Would Like You To Get The Fenders If They Are Not Rusted Out Also If The Tailgate Is In Good Shape I'm In Need! Hows The Hood? Door Rubber? Wiring Harness If Its Not Rotted Away, Rocker Chrome If Its Not All Beat Up Either Side.
  7. How about gen1 lift kit, Subframe connectors, upper strut tower braces?
  8. I have spent alot of time in the auto store searching for the perfect hoses and found some near perfect matches, I will have to dig up the receipt for part numbers but the hoses I know were from goodyear! And they had the right bends I just had to trim to length. They also made two different size inlet & outlet spigots of the heater core so you may need to look into that.
  9. I've come across that situation with a few of my subs it's usually a bad connection have you taken your taillights all the way apart ; If you pull the bulbs out you can push the bulb conn. out from the back and check the solder from the wire to the the little disc which makes the bulb conn. sometimes they are kind of green and or broken.
  10. I have a complete MSD 6 offroad ignition on my 1600, plus weber and exaust and it kicks a** !
  11. You might want to follow the wires in the back and look for cracks where it could be shorting, Or the inside of the taillights is corroded possibly.
  12. 73' gl coupe,78'-79' wagon, brat,and coupe 1. rear window seals for any coupe! 2.frt. turn sgnals and valance for 73' gl coupe 3.rocker panel chrome 4.fuel tank sender 78' gf probably any coupe would do 5.Battery trays 6.drivers side fender 78'-79' 7.Brat tailgate no dents or rust 8.1400 5spd shift link 9.dfv manual choke weber 10.doors with no trim holes,dents. 11.carpet black 12.corner marker lights for 79' (slimmer style) 13.rear view mirrors that arent QUITTERS 14.coupe headliner off-white 15.coupe or brat door panels black or brown 16.upper strut mounts (new) 17.right and left rear qtr. panels in mint for 73' gl 18.corner window rubber for coupe pop-outs any up to 79' 19.GF trim behind corner window with no broken clips 20.Rubber seals for all lens' 21.Wiper transmission for the 73' I believe any till 77' will do 22.rear apron 73' GL 23.73' dash GL 24.Rear bumpers 79' wag or brat & 73' coupe 25.Wiring harness 78' 79' GL 26.jdm 1600 27.5spd and 4spd 2wd trans mounts, 4wd trans mounts 28.window scrapers coupe with chrome 29.Any nos body parts 30.handle pull cups interior in black & brown 31.headliner wag. off-white And anything for any gen1 in new or perf. cond.,
  13. I have one on all my cars it really improves road feel , but sometimes your steering joint becomes loose you can tighten it by squeezing the bearing cups tight and re-staking them either that goes or the lower steering column bushing and washers wear out.
  14. Found rear shocks by PRO-COMP, & KYB. VW urethane steering coupler, also a throttle return spring mount in chrome for a Chevy.
  15. I have a set of pro-comps on my 79' wag and a set of kyb offroad shocks on my 78' brat I'll get back to you with some part #'s
  16. You might try to see if a 1600 2wd bellhousing with side mount starter usually out of 84' and newer ea71 might help, Its got a larger clutch and may fit a ea81.
  17. Hey there subgsr I have a 73'gl & a 78'gf I was wondering if you knew where I would be able to find rubber seals for the windows & doors? I'm also in need of frt. turn lens & or assy.
  18. Hey Garner If You See A Spoiler That Might Fit A 73' Or 78' Coupe Or Maybe The Louvers From The Rear Window Snatch'em Up, And I'll Race Ya Shortly.
  19. I Have Two Dual Carb Setups But No Air Cleaners, If You Find One Hang Onto It For Me I'm About Two Steps From Putting It On My 78' Brat With The Factory Carbs, And I Believe You Need The Specific Carbs Due To The Jetting, Side Of Carbs Say Left & Right Respectively. If You Want To Weberize The Dually You Need 1 Dgv & 1 DFV With Manual Chokes Because The Ports Are To Close Together Auto Chokes Clash.
