yegoshin
Location
Bay Area/SLO
yegoshin's Achievements
Advanced Member (3/11)
10
Brumby conversion: EJ22, hybrid AWD center lock, SUCCESS!!!
yegoshin replied to Phizinza's topic in Subaru Retrofitting
you are right, it needs to be connecting ether a ground to the ECU or a +5V, my guess would be a ground. but basically the reed switch just interupts the circuit displaying a square ware between 0 and 5 when the car is moving. -
where in Australia are you again? my mom is going next weekend and could possible bring you an extra speedo with the sensor and all. are you interested? She is traveling to Melbourne -
if the wiring from the 2002 imp harness is different from the earlier age one then it will not work. Your best best as said before is to take a manifold/ECU/wiring off a pre imob impreza
I don't have the manual in front of me but this I know. If you measure the resistance with a MM it will fluctuate between 0 and some number. The quicker you drive the higher fluctuation frequency you will see. Thus I belive that the sensor wires need to be connected like this: A -> ECU B -> ground OR 5volts depending on what the ECU wants.
well its a D/R non turbo (the regular axles from my brat fit and as far as I know its not modified). I tried ohm metering it while shifting but still can't seem to get anywhere. I really would like to wire it in with the rest of my harness instead of later on top of it.
Ok since we are ALL on this here topic. could someone please tell me what is the pinout on the 2 connectors (a white one with 6 wires and a black one with 2 wires) from the EA82 transmission? Pretty please with sugar on top? Oh and I have seen http://rides.webshots.com/photo/1164047204042305049ntcJbF I need to know which wire is which because silly me put the tranny in and cant see the sensors.
they *should*, I doubt that the temp sensor is drawing much current but just double check if you can. Put an ammeter between the gage and the sensor to check the current. Multiply the current by current by the resistor value and you should get the Power that resistor needs to dessipate. That value should be stated on the RadioShack resistors.
this is what you want to do:
Ok here we go: To make the EJ temp sensor work almost in the EA guage you need to do the following: hook up a 275 Ohm resistor with one lead going to Ground and the other lead going to the wire from the Temp sender to the guage. This will do the following to your Temp Scale: (you can view there "excell" file here http://dima.brandtshaft.com/Subaru/SubaruTemp.htm) A little EE here for those that are interested: R_total=1 / ( (1/R_temp_sender) + (1/R_extra_resistor)) so when we plug in the 2 EJ temp sender values and the value of the extra resistor we get the values that the gauge would be reading. Looking at the graph those values make a line that almost perfectly matches the EA temp sender line. I belive this will work but haven't tried it yet. If someone does try let me know. This is the way I am going to go with my swap as its much EASIER then tapping the engine or welding something into the rad/hose.
Yes I am aware of that, you have 2 options there. The red part of your statement is actually partly incorrect I belive. 1) design an actual circuit that will make those 2 graph lines match 2) Live with it and know that your guage will actually be MORE sencetive on the HOT side and LESS on the cold site. EDIT: I have now applied the resistance formula and it seems that the graphs will line up practically perfectly see below
EASY. To lower a resistance all you have to do is wire in a second resistor in PARALLEL (mean that the second resistor has leads going to temp gauge wire and ground). This will drop the overall resistance in as seen by the guage. formula for calculating it is here: http://www.1728.com/resistrs.htm I am too lazy to calculate right now, maybe in a bit if you ask nicely
Don't use a turbo 5 speed unless you want to mess around with axle splines. They are different then your 86 brat's (23 and 25 but search to confirm). You will need to modify the mounts off your 4 Speed and put them onto the 5 speed. Also the driveshaft will ether have to get elongated or you need a 2 piece one from the 5 speed car. You also need all the shifter linkages from teh donor car.
care to mention those 10 wires here? I am just trying to see if I got my harness right. So far I got: Radiator Relay VSS Fuel Pump Power to Fuel Pump/Main Relay Neutral Position Switch Check Engine Light Starter Wire to the ECU Ignition Wire to the ECU Test Mode Connector(? technically already on the donor by itself) Tach Signal anything I am leaving out?
So I decided to start a blog if you will pretaining to my convertion. I can post pictures of most things just ask away. I am a the point of wiring this thing up so, if anyone out there has an FSM Wiring diagram for an '85 BRAT (or anything close to it) I would be eternaly greatfull to you. Here is a picture of my current wiring harness (not including the EJ one yet): I am going to take apart the harness and trash all the stuff I don't need. I know some people would call it exessive. I understand but I would like this to be a clean install. I would like to achive a state where all the wiper/lights/etc are kind of thier own separate harness and if in the future I want to drop in another EJ engine all I would have to do it put the old EJ wires out and drop the new wires in.
