About leadfootracin
- Birthday 05/16/1959
Location
seattle
Vehicles
91 legacy 94 legacy
Recent Profile Visitors
leadfootracin's Achievements
Advanced Member (3/11)
10
Need help, sold my fsm with my xt. I now have a 1990 loyale wagon 4eat all wheel drive, the story goes bought wagon, rear diff blown up and cought on fire, r&r diff with used, correct ratio, drive car severe tourque bind always, even with fuse in, test all soloinds good, check tcu pinouts,tcu internal short always applying duty c soloind, r&r tcu with junkyard unit, works fine for 3 years, sold xt and manuals. Now loyale locks up tourque converter randomly, will do it cold, at idle, foot on brake, from park to reverse, nuteral to drive. Its locked up enough to kill the engine, somtimes it will work fine, no rhyme or reason. I think its electrical, changed tcu again same prob. has anybody else seen this? Was wondering if anybody has a transmission wiring diagram they could send me? Thanx
Replacing fuel pump 91 Loyale ea82, compatibility?
leadfootracin replied to BCO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a Fuel pump from a gm throttle body system will NOT work, only about 15# pressure. -
Will a GM alternator hurt in any way?
leadfootracin replied to SakoTGrimes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
gm internal regulated alts are pretty good at idle, if its not quite enough the pulleys are interchangble, smaller pulley, more output at idle. I just wanted to use the flamethrower:burnout: -
Do not use starting fluid on a gas engine!! If the engine is out of time, or it has an spark problem it can and will shatter pistons, break rods, blow out oil pans, valve covers, intake manifolds. Use carb cleaner, if the engine is going to run (bad fuel system etc) it will run on carb cleaner. I have a ball of aluminum on my shelf that used to be a piston, (starting fluid and mistimed spark) my 2cnts
Bulb # 89 :headbang: same base smaller bulb, used for underdash lights on gm and markers on a lot of cars:burnout:
Crap a CV! Can anyone help?
leadfootracin replied to yodannyc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am not in vancouver, but I charge $150.00 per side installed for almost all cv shafts, most cars that includes the shaft, reman. A lot of shafts are becomeing avail new for $5 or $10 more due to lack of cores. if I install a new shaft there is no core. check your local parts stores, ask about new? Easy install. good luck. -
Calling Delta 272 CAM People!
leadfootracin replied to Steveman09's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on ford 2.3 ltr engines we use dimes, cost 80 cents to shim a set, re ground cams are that, reground. if you specify new billets you dont have to shim them. -
well... still not runnin
Warning, do not use starting fluid on any gas engine, ether, (starting fluid), will break pistons, bend rods, blow the oil pan and or valve covers off, use carb cleaner or gas, if the engine wont fire find out whats wrong, (no spark, fuel, timing, etc) I have a shelf of parts, NG from engines that people have tried to start with ether. any car that comes into my shop with starting fluid cans in it, the starting fluid gets thrown away and the owner is warned that any engine repairs have no warranty. my 2% JR -
thumbs to the OUTSIDE of the steering wheel...
leadfootracin replied to scrap487's topic in Off Road
1st thing your tought racin stock cars, keep your fingers outside the wheel. :-\ -
what $100 buys you
leadfootracin replied to tailgatewagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your wagon's bigger than your hatch. be very carfull going downhill. :headbang: :burnout:
