Changed 02 sensor front.
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNGK sensor.but that code was not on before
Changed 02 sensor .front .erased code .check engine came back on heater control circuit this code was not on before .any help 2000 forester.a/t
2 issues .cruise control. Thermo switch
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure what u are saying
93 impreza sedan fwd.cruise control not working location of Thermo switch
93 FWD automatic heat problem
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems that the relay is grounded out .with ground wire so will check .ground and relay. both fans running all the time is ok.but not necessary.
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRefresh my memory where is the sensor that control the fans when temp goes up.both my fans are on all the time
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is that cable called
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes after 2 hrs figured it out.flush out etc... The cable is bad. That lets cool or hot air in.vent was open.radiator .thermostat good.so if anyone has problem .check vent door first
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDumb question .which does thermostate go point up or down
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk.thanks good suggestion
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStrange thing is a ground wire from relay under the hood.thinking. Is wired to run both fans.so problem has been there awhile
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes thinking that also will check before buying radiator.temp control works but cold or hot still very hot inside.finally getting warm around here thanks
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr would a flush out work?
Subaru cars replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid research .thinking bad radiator
Subaru cars
