nelstomlinson
    3
nelstomlinson last won the day on March 27 2023
nelstomlinson had the most liked content!
  • Location
    Delta Junction AK
  • Referral
    Searched for p0170
  • Biography
    We bought this Subaru nearly new in 1997. It was a high mileage program car. It has been reliable for 19 years, but now we have problems. I'm hoping to get another decade or so out of it.
  • Vehicles
    96 Legacy wagon x2, 2001 Legacy Outback wagon
Recent Profile Visitors
1079 profile views
nelstomlinson's Achievements
USMB is life!
USMB is life! (4/11)
26
  1. It seems we can only attach 438kB of files total for the whole thread? that means one picture per thread!
  2. Yanked the '96 engine out. Lots of crusty oil on it, can't see where it was coming from. Pulled a valve cover, the gasket looks peachy, but we'll put in a new gasket anyway. The inside looks nice and clean, no signs of crud. Notice that keeper bolted onto the back side of the head. It's not on the back of the other head, no keeper thingy there. We've pulled the flywheel off, this is the subie that was breaking flex disks every few hundred miles. We'll put the flex disk from the '95 on and hope for the best.
  3. We put a new belt, sprockets, water pump and so on onto the '95 right after we towed it home, and toward the end noticed that the keyway on the crank nose was damaged, and the crank sprocket had been jb welded in place. We think it was glued on a little bit out of time, and the engine won't start. Gave it a whiff of starting fluid and one cylinder fired while we cranked...looks like this engine is done. We'll pull the engine from the '96 this week, probably, and swap over the new belt, etc and the flex plate from the '95. The timing kit is the same for both engines, per the kit instructions. You say to swap the intake? Why is that?
  4. We have a '95 Legacy with automatic transmission and a damaged engine, and a '96 with a strong engine and problems with the manual transmission. The '95 has a great body and it makes sense to swap the engine over to it. Obviously we need to replace the flywheel with the '95's flex plate. Will that mess up the engine balance? What other problems are we going to have?
  5. Yes. It's been too long, I can't remember the numbers in the manual or which of the three it was, but it was indeed one of those three connectors.
  6. So far it's parked in a field, because he thinks it's too hard. It really doesn't look any harder than a timing belt, just a couple more steps. I'll see if he wants to open it up. If he does, it'll almost surely need a timing belt, etc.
  7. A friend has a '99 with a replacement engine from Japan. He believes it needs a new oil pump. He's quite sure that this engine requires different parts than the original did, but "engine from Japan" is all the info he has. What am I looking for to identify that engine, and how do I search for parts to help him out?
  8. And it's running. It turns out that there isn't a little square mark on the front of the crank cog, instead there's a little line on the tone ring in the back. _THAT'S_ what has to be lined up with the witness mark on the engine and with the line on the belt. The last one I did was the '02, and it did have that square mark.
  9. I don't think we've ever done a Subie timing belt in just once, we have to do and redo every time.
  10. The problem is that we don't do this every year, so we don't remember about the square mark versus the little arrow. We also just realized we forgot to pull the pin out of the tensioner, so we would have had to go back in there anyway! Oh, well, that's going to make redoing it way easier, so it's all working out.
  11. This one is definitely not interference, we can bar the crank over with the cam in any position.
  12. And my son just found a picture of the crank pulley properly lined up. We should have lined up the square mark, not the notch 90 degrees away from it. Oh, well, we'll do it again tomorrow.
  13. We got the new timing belt in, and now when we try to crank it over it doesn't want to turn. We can bar it over by hand with no problem, if we take the spark plugs out it spins over quickly with the starter, but with the plugs in place it sounds as if the engine is kicking back against the starter. The Aisin waterpump kit was all made in Japan stuff except for the Mitsuboshi timing belt, which was from Thailand.
  14. In the worst case, you're probably getting at least $300 worth of parts for the next one you buy.
  15. The current water pump is an aftermarket already, we replaced that around '17 I think. I need to get the maintenance log out of the glovebox and re-read when we did what on this one. I think what you're seeing that looks wrong is the broken belt is bunched up above and left of the cam pulley. It does look a little like the toothed idler, I guess.
