nelstomlinson
3
Everything posted by nelstomlinson
We put a new belt, sprockets, water pump and so on onto the '95 right after we towed it home, and toward the end noticed that the keyway on the crank nose was damaged, and the crank sprocket had been jb welded in place. We think it was glued on a little bit out of time, and the engine won't start. Gave it a whiff of starting fluid and one cylinder fired while we cranked...looks like this engine is done. We'll pull the engine from the '96 this week, probably, and swap over the new belt, etc and the flex plate from the '95. The timing kit is the same for both engines, per the kit instructions. You say to swap the intake? Why is that?
We have a '95 Legacy with automatic transmission and a damaged engine, and a '96 with a strong engine and problems with the manual transmission. The '95 has a great body and it makes sense to swap the engine over to it. Obviously we need to replace the flywheel with the '95's flex plate. Will that mess up the engine balance? What other problems are we going to have?
A friend has a '99 with a replacement engine from Japan. He believes it needs a new oil pump. He's quite sure that this engine requires different parts than the original did, but "engine from Japan" is all the info he has. What am I looking for to identify that engine, and how do I search for parts to help him out?
And it's running. It turns out that there isn't a little square mark on the front of the crank cog, instead there's a little line on the tone ring in the back. _THAT'S_ what has to be lined up with the witness mark on the engine and with the line on the belt. The last one I did was the '02, and it did have that square mark.
The problem is that we don't do this every year, so we don't remember about the square mark versus the little arrow. We also just realized we forgot to pull the pin out of the tensioner, so we would have had to go back in there anyway! Oh, well, that's going to make redoing it way easier, so it's all working out.
We got the new timing belt in, and now when we try to crank it over it doesn't want to turn. We can bar it over by hand with no problem, if we take the spark plugs out it spins over quickly with the starter, but with the plugs in place it sounds as if the engine is kicking back against the starter. The Aisin waterpump kit was all made in Japan stuff except for the Mitsuboshi timing belt, which was from Thailand.
The current water pump is an aftermarket already, we replaced that around '17 I think. I need to get the maintenance log out of the glovebox and re-read when we did what on this one. I think what you're seeing that looks wrong is the broken belt is bunched up above and left of the cam pulley. It does look a little like the toothed idler, I guess.
Just driving along and the engine shut down. The only stored code is P0340, cam position sensor. The P0170 fuel trim code was pending. We put in a CPS from an engine that ran when we parked it. Didn't fix it, so we checked continuity from the CPS connector to the B20 connector at the back end of the engine. Wires are good. We checked continuity from the B20 connector to the B84 connector on the ECU. Wires are good. What else should we check? We will have a new CPS from NAPA tomorrow, but new electrical parts are a crapshoot...
A little update on this. I had bypassed the ignition switch, ran power from battery to starter solenoid through a momentary contact switch on the dash. We noticed that it only started hard if we turned the key to on, then cranked the engine. If we turn the key briefly to start, then let it go back to run, then push the starter button, it starts easily. Probably the computer is confused. With all the problems my old diesels have, they are still so much better than this.
