Everything posted by nelstomlinson
- Junking a couple subies, what to keep?
I'm rebuilding a ej22
nelstomlinson replied to Zip Tie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGeneralDisorder, is it even possible to get oversized bearings for these older subie engines? If we're having the mains line bored, we need bearings bigger on the outside, and if the crank is ground, we need'em smaller on the inside, too!
95 Legacy AT in -30 weather
nelstomlinson replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm in Delta Junction, a little south of Fairbanks. Yes, use an oil pan heater on your automatic. We all do that up here, because our transmissions last longer that way. I used to do it on my manual gear boxes, too, before the synthetic gear lubes came along. Also consider a synthetic ATF. One morning 30 years ago I was driving in to work in a two-ton Chevy, and I tried to shift the two speed differential. It was about -40, and the stinking thing was too stiff to shift ... I was coasting, couldn't get into gear. I got lucky and it eventually went back into the other position, so I didn't need a tow. I bought silicone heat pads for every gear box that shifts after that. My modern gear boxes from the '80s use synthetic ATF, so the situation is less dire now.
3pin, the '02 is a daily driver, looking pretty solid so far. You probably meant the '01? I don't think it got badly over heated. I've had American engines get much hotter with no harm, but they weren't recycled beer cans, either. I do plan to tear into that engine someday, and if the crank isn't scored, it'll get new head gaskets and go on sale in the local Craigslist. It's a 2.2L, and the '02 is a 2.5L, so I don't think there will be much that interchanges besides stuff like the alternator. The two ''96s are both excellent machines. The one with an automatic I've had since it was a year old - bought from a dealer it as a high-mileage program car. That's the closest I've ever come to buying a new car. The one with a manual I bought cheap last year from a mechanic who was tired of working on it. It looks as if it's going to be a good one. I think the '99s manual trans will be a spare for that one? I'll eventually tear apart the DOHC 2.5L in the '99, too. That one had a rod knock before it stopped running, so it's probably going to be scrap, but I'll check. Some day I hope to wean my wife off these teeny-tiny go carts and get her into a diesel truck, but until I have the right truck built for her, these little subies are fun to drive and not too bad to keep running!
I have a '99 Legacy Outback wagon and a 2001 four-door Impreza, both with blown head gaskets. The Impreza is smashed on the passenger side, really not worth fixing, the Legacy has no title, really not worth fixing. I also have a 2002 Outback wagon and a pair of '96 Legacy wagons, one an Outback and one not. The two junkers are going to get stripped and go to the junkyard. I'll keep what I can use, and sell what I cannot. That leads to my questions: Will the front clip from the '99 bolt onto either of the '96s? I don't care about changing the appearance, but will it bolt on? Same questions about the doors, and other body parts. Similarly, will any of the Impreza body parts bolt onto the 2002? Again, if they physically fit, I don't care about appearance. The compatibility of the mechanical stuff I can figure out, pretty much, from the Rock Auto catalog and from help you all have given me earlier. Thanks!
Matching a replacement tire
nelstomlinson replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's just a nail hole, jam a plug in it from outside and run it. A cut sidewall would require a boot, and most tire shops use safety concerns as an excuse to sell you four new tires, but a nail hole doesn't compromise the structure and you can easily plug it from outside, no tire shop needed. Or, just put some green slime in the tire and run it. I've had fair luck with that stuff.
Naked smooth roof- installing roof rails??
nelstomlinson replied to Mitchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would suggest that you consider 3M 5200 rather than silicone. I have Yakima Q-towers on a '96 Legacy, and they have worked well since '97. No problems in use, and no damage to the roof.
'96 Legacy 2.2 engine hesitates and surges P0120
Not fixed at all! The problem is intermittent, and it's back. As before, the live data shows the TPS value falls to zero (the gas peddle is depressed and the throttle is definitely open) and then it jumps back up to a correct value, causing a surge. I'm back to suspecting a bad wire or bad ground. For now, the engine runs just fine with the TPS disconnected, which means the computer is getting a 100% reading. We can live with that for a while.
Interchangeable Transmissions?
Sort of on topic: would a '99 5MT from a 2.5L DOHC fit behind a '96 2.2L? How about a '01 4EAT from behind a 2.2L to go into a '96 2.2L? More generally, is there any kind of chart that shows which lego pieces interchange? It looks
I tested the resistance between E13 pin 1 and ground, got 136 Ohms. That's obviously bad, so I found the other end of that cable at the E2-B21 connectors. There are three engine-bulkhead connectors mounted to the passenger side of the engine, down low. E2-B21 is the 12 pin connector in the middle of that stack. I unplugged that one, and put on a smear of dielectric grease before I re-plugged it. Then I read -5 Ohms. I figure the negative resistance indicates there is some stray voltage, but I'm not going to worry about that yet. I plugged the connector back onto the TPS and took a test drive. Same problem! Now that I have the scan tool , I could check that, and it was indeed the case. I probably was at 1/8th throttle before the TPS value got off 0%. With Key On Engine Off I twisted the TPS until the scan tool reported the smallest non-zero value I could manage, about 0.4%. I drove about 50 miles and I think it's fixed.
Thanks. I should have said in the original post that I did replace the fuel filter and test fuel pressure early on. That is an excellent thought! I'm accustomed to AC power, and I don't have the habit of thinking about power flowing through anything but wires.
I got a scan tool, an Autel AL629, and looked at some data. What I found is that the TPS reading jumps about wildly while the engine is bucking and surging and hesitating, and drops to a steady zero once the thing stops misbehaving. Unsurprisingly I now have a P0121 TPS range error as a stored code, along with the P0120. My best guess right now is that I have a bad connector or broken wire somewhere in that circuit, and when it makes contact and the signal gets through it's all noise, and when the broken wire isn't making contact at all, the circuit reads zero. I plan to test that hypothesis by disconnecting the TPS entirely, and driving for a while to see if that intermittent problem returns. I haven't put an analog vacuum gauge on it yet, but the scan tool shows that manifold pressure responds as expected to throttle operation. The scan tool probably wouldn't show the flutter that could show up on an analog gauge, and I should get my old analog gauge on there.
Thanks, heartless. I was able to retrieve that from http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1996/Service Manual/ENGINE SECTION/ENGINE/MSA5TCD96L5971.pdf It does look as if a vacuum leak is a likely candidate for surging and hesitation. The throttle position sensor that I keep getting a code for doesn't even show up on that chart. The TPS is new, and its resistance measures OK, so I don't think it's causing the code. I have a vacuum gauge. As I recall from carburetor days, if the idle vacuum is low, or fluctuating, there is a significant vacuum leak. Does it work that way for fuel injection?
FerGloyale, mine is the three pin TPS. Is that the kind you're talking about that has the fully closed switch? Can you point me to a description of the procedure to set it? I still haven't found that. Also, do you know if that 4.6V open circuit reading on the center pin of the connector is OK?
OK, that makes sense. Where do I find that procedure? I have downloaded a factory service manual PDF, do you know where that procedure is in there?
I cleaned the throttle body as best I could, no change, still have the same intermittent problem that only shows up once the engine warms up. I can't clear the P0120 code until the engine cools down. I removed the connector from the TPS, and the center pin shows 4.6 Volts. Should that be higher? Obviously, it's the three pin TPS. The new TPS shows about 5kOhms resistance between the outside pins, and the center pin to outside pin resistance varies smoothly from about 60Ohms to 5kOhms. I found a couple threads on how to clean the throttle body. The instructions varied from ``Don't even try, you'll ruin it!!!'' to ``Spray it with Gumout.'' I cleaned it inside with a rag moistened with a little WD40, until I couldn't get anything more out. There was definitely a lot of carbon in there, but only a thin coating, not thick piles of crud.
No. How do I do that? I have a couple cans of carb cleaner at home; can I just spray some in there while I rev the engine?
I have a throttle position sensor error, P0120. After the engine warms up the engine will eventually start to hesitate and then surge, as if I was taking my foot off the accelerator and then pressing it again. After a bit of surging, the check engine light comes on and I can read the P0120 code. Warm or cold the engine starts and idles fine. If I clear the codes and drive some more, the surging and TPS error will return after a bit. It never happens until the engine has been warm for several minutes. I replaced the TPS and the problem didn't go away, so I don't think it's the sensor causing the TPS code. Does anyone have any recommendations for what else I should try?
Engine swap? 2001 Impreza auto to '99 Legacy 5 speed
Two more questions on this business. I have a line on a running 2014 2.5L engine, pulled from a wreck. 1) Can anyone tell me whether this would play nicely with the ECM in the '99 Legacy 2.5L DOHC? 2) Would it be reasonable to use this as a new bottom end with the '99 Legacy 2.5L DOHC heads and ECM? Or maybe just use the crank and con rods out of this engine to rebuild the '99 engine? Unfortunately, I still haven't pulled the bad engine out of the '99. Maybe this spring, after it warms up. It was -24F this morning.
I won't know until I open it up, but rod bearings is what the fellow who gave me the car suggested was wrong. Thanks for the suggestion; that might be a good option.
If I luck onto a pre-'99 EJ22 cheaply, I might go that route. On the other hand, I would enjoy doing a rebuild. Either way, the first step is going to be removing the current engine. The problem up here is freight costs. It would probably cost more to ship an engine up here than it would cost to buy it down there. I've never seen a Subaru engine on Craig's List here, and finding that '01 with a trashed body for $1,000 was a happy surprise that isn't likely to happen again.
I found the Subaru Technicians Reference Booklets and have been reading up. It looks as if the easiest, cheapest route to resurrect the '99 might be to rebuild the engine. Next step will be to pull it out and see how bad the bottom end really is. The 2001 has a trashed body, so it will have to become a parts car eventually.
EJ22 Salvage Yard Bait-and-Switch Ripoff. Ideas about how to proceed?
nelstomlinson replied to brycarp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can prove that they lied about the mileage, I'd suggest small claims court. Also, maybe file a fraud complaint with local law enforcement?
Wtdash, I want to drop the entire, running 2001 Impreza engine into the '99 Legacy, and bolt it to the Legacy's manual transmission. I'll toss the old Legacy engine. There won't be any swapping of heads or anything like that. Are you saying that the older Legacy flywheel won't fit the newer Impreza engine? Or the engine mounts are different? Or the bell housing has a different bolt pattern? Or maybe all of those and more? Is there a primer on here that covers issues like this? Things like Phase 1 and 2, EJ22 and EJ25D are greek to me so far, and I'd like to fix that.
