Downwash77
Everything posted by Downwash77
5mt duel range rebuildable?
Downwash77 replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sycros are fine I only threw the question in because I was asking about part availability, Thanks. -
Hello, I have a 5mt duel range transmission in my brat, I would like to have it rebuilt (noisy bearings) it's annoyingly whiney, are there parts avaliable to rebuild them, bearings, sycros, I'm shure someone has been through this, thanks.
Earplugs!
Subaru Repair Manuals
Downwash77 replied to Mastremarx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was once talking to a subaru mechanic about timing belt replacement, he interrupted me by asking me "do you have a hanes manual?" I replied yes,he replied "good throw it in the garbage" point being,there is absolutely no substitute for a factory manual. -
Hello, anyone know who makes the best fitting sun shade, the kind that keeps the dashboard fromm getting fried. I seem to recall having one back in the day that didn't fit well, this is for a second generation brat, it seems worth asking, thanks.
Webber 32 36 running to rich
After removing my carb I discovered I few things, the fuel in the bowl was very old, (residual gas in lines left after pumping tank dry), a vacume leak(certainly dosn't help matters) and lastly the float was a bit high. Thanks 87 bomber for the jet size verification it was essential to eliminate that question. The car runs mint now! -
It's running rich at idle, haven't gotten any further then that, the amount of fuel seen coming out of the primary venturi looks to be about five times the amount coming out the venturi on my proper running wagon. Fuel pressure is correct. Whom is best to call about replacement jets if these are incorrect, thanks. -
I finally got my brat running, webber 32 36 running rich, any ideas why? Thanks in advance
New camshaft for ea81?
Sadly they are worn worse then I've ever seen on a subaru. I had no choice but to leave them.thanks for the input! -
Are new camshafts and lifters available for the ea81, mine are worn pretty badly. Thanks.
Thanks, I will try that
I'm am very close to getting my brat running but I'm in need of a distributor cap seal. I can't seem to find one anywhere thoughts on where to get one. Thanks
The traditional fit of the axles feel loose on the stubs. You should be counting the corresponding tooth spaces on the internal spline. I say this because the tooth count differences sound fishey.
Thanks, I ended up making some bushing on my lathe, seemed like the the fastest solution, I haven't tried them out yet but it appears they will work well. As for help with transmission identification, that will no doubt serve as helpfull in the future. Thanks again
It's a 5 speed duel range transmission, it's been swaped into a brat, not shure what the transmission came from
Are shifter bushings available for replacement? Thanks
rainwater leaking through dash
Downwash77 replied to old McD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a windsheild in stalled by safelite autoglass and was overwhelmed with regret, the seal didn't even fit properly, I promptly purchased a oem seal and am to have it installed by a real glass shop. -
EA82 oil pump problems
Downwash77 replied to Mustakrakesh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you tried a easy out? -
Looks like I will be going to napa. Thanks much
Brake caliper questions
Downwash77 replied to Rocketdog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As far as adjusting the caliper piston in, I've always used a small adjustable wrench using the jaws as a spanner wrench, the piston is to be turned cw (righty titey) -
Hello, I just ordered wheel bearing seals from advance auto and they looked nothing like the original, a presumed they were wrong so I didn't take them home, now I'm thinking they are equivalents, any thoughts.
Clutch extension spring location
Thank you all for your help! -
Sorry, 86 brat ea81, thanks
