Downwash77
Everything posted by Downwash77
Yes 10×1.25 is correct, flange nuts are prefferable.
Hello does anyone know exactly where the extension spring, (that's helps pull the clutch fork back) connects to? Thanks
I'd be torn between the alloy H and the white spoke wagons. The H alloys are very unique but you can't beat the rugged iconic look of the wagon wheels. The alloys are hard to come by they may never cross your path if you decide to change
EA81 crank pulley bolt RH or LH
Downwash77 replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks the rope trick savedyou rump roast! -
Thanks! -
Is the front crank pulley bolt left or right hand, can't get it off with impact, don't know if I'm making it tighter. Thanks
5mt duel range clutch fork
Thanks all. I will order tonite -
Hello, I need to replace the clutch fork on my 5mt duel range. The transmission is in a brat therefore I don't know the correct type or year to order the part for. I think 85 89 but I'm not positive. Thanks
5Mt duel range transmission identification
Thanks!! I will order one asap -
Second generation brush gaurd for sale in ct
The brush gaurd has been sold. -
Looks lIke I will put felpro gaskets on and call it a day. Thanks all for your help
It is so, according to subaru's literature ver Batem ( apply sealant "three bond 1201" or equivalent evenly to both sides of cylinder head gasket with a brush) .
My factory shop manual says to use sealant when replacing the head gaskets, it says to use tri bond or equivalent, what is the equivalent? Is sealant even nessacary? Thanks
Does anyone know the best paint brand match and color for ea81 tan interior. Thanks
Door activated chime troubleshooting
Downwash77 replied to Dogbrain's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The fact that the chime works with the key out indicates that the problem may be in the ignition switch. It seems the switch may not be turned back far enough but still releasing the key. My 01 and 83 do that intermittently. Try turning the key in the more off position if it's chiming when it's not so posed to. Removing the annoying noisemaker is also an option -
Transmission swap options for ea81current 3at
Thank you very much.
