91subaru-Bruce
Location
Vancouver
Interests
Cars of course, metalwork, general tinkering with things...
Occupation
Civil Engineer
Biography
Always been a car guy, enjoy restoring old cars but mainly end up being mechanic for my family. Enjoy the outdoors and home projects.
91subaru-Bruce's Achievements
Member (2/11)
10
Did they check the electric fan, relay, sending unit? Did they pressure test the cooling system? Is their any exhaust smell in the antifreeze? Coolent hoses in good condition (they will collapse sometimes if old). FYI, you should never remove the thermostat, that's a good way to damage an engine (especially in cold weather). The fact that the mechanic did this as a solution leads me to believe he doesn't fully understand the cooling system. my .02
Even if it's extra work it'll be well worth the help and the piece of mind knowing that it's not the alternator! I tried to check my mother in laws sub but it has a different plug that doesn't allow me to tap into the yellow lead easily (with it plugged in). I'll check it if the new alt doesn't solve my problems... Looking at the wiring diagram, I was wanting to find out where the ignition relay is. If that was somehow bad it could be leaking power back through the circuit? Not sure where it is though...
Ok, I pulled the alternator and will get another tomorrow. Then I can at least take that off the list. I'll let you know how that goes tomorrow evening. Hopefully I'll have my little subaru back on the road becaused it's supposed to snow on saturday! Thanks for the continued help. It suprises me how much people are willing to share knowledge on forums!
Ok, I tested the Alternator yellow wire and yes, the light goes on. Does this necesserally mean the alt is bad?, or could something else be at fault and cause that circuit to be completed (or is that yellow wire never supposed to have power through it even with the ignition switch in the "on" position?) I also pulled every fuse and relay in the two fuse box's and the power never goes out (with the alt plugged in and the ignition switch in the off position).
Well, out of curiosity I checked my mother in laws subaru to see what had power and what didn't and the yellow wire has power when the key is off as well. So now I'm thinking that maybe my new alt isn't bad (seemed unlikely anyway) Looking at the wiring diagram I still suspect the mpfi diode, but I can't seem to find it. If anyone knows where it is (or at least what it looks like) I'd love to know. The diagram that was posted show's it right near the fuse box under the dash but I can't find anything that even looks close... Still open for ideas on what to check next...
