Tony_de_whitt
Everything posted by Tony_de_whitt
Ok engine guy re measured and realised he had made a mistake. compression ratio has been recalculated at 10.2 using the components above. all back on track and happy again. one final question is...- how can I tell if an engine block that was in the 99 outback hybrid model which has the new block old pistons. is such an engine??? if it has been removed. for example I have the chance to look through 26 short blocks. Is there a way I can tell which is the hybrid one. Piston makings?? block markings?? etc etc cheers ant
So in the end we didn’t have the choice to use exactly what we wanted. i will ask the engine man today. im pretty sure he has used standard pistons and a late block he had to take a fair bit off the heads is all I know and then did his calculations. Unsure if his method of calculating the ratio but he did mention using kerosene. is there an easy method to measure the ratio?? i will try and get some sizes of the parts he has used
Ok do we have advanced somewhat using the advice received in here. The guy who I am working on this with was keen to do a few calculations before assembly. this is the messsge he just sent me Hi Anthony, Compression ratio measured and calculated at 12,375 with standard thickness head gasket of 0.55 mm. Check on line and see what feedback you get it seems too high to me. Cheers Rob. So is this measurement possible?? is it too high?? should we reduce with thicker gaskets?? thanks again
Thanks Yes s i did read about using the 251 pistons. any ideas where they will sit in relation to the top of deck?? i thought using the .051 cometic head gaskets allowed for the 99 pistons to stick out of block and therefore give higher compression ratios. Which is is what makes the frankenmotor what it is. thanks again
So can anyone help with this final issue?? ive sourced a late block. 52mm journals etc etc we are using the cometic head gaskets .051 thickness when searching for the early pistons there seems to be a few different sizes to choose from. Can someone possibly confirm what size piston will work best and give the most compression but not cause me issues?? I’ve been looking at 1998 outback pistons with a choice of 2. and how far these pistons should sit in relation to the top of chamber?? Thanks again
Ok Pretty new to all this so apologies if I need spoon feeding. So I need the hybrid 99 model Ej25d or can it be any Ej25d?? swap out the pistons for 251,s what are 251 pistons out of?? 642 head gaskets I’m unsure what you mean? and which heads are you saying to use?? Are you saying just use the same heads and keep it as a complete Ej25d engine heads and manifold?? then swap all my electrics from my current Ej22 set up and put them onto the complete Ej25D engine. and my current wiring set up will run this engine fine?? also what sort or Hp would you get just using ej22 heads and a later Ej25 frankenmotor in comparison to the above set up?? appreciate your help on this thanks
General Disorder i appreciate your knowledge and thanks for your reply. i think the sort of power your talking about is way above why I’m after its a frankenmotor I want and it’s the ej22 heads I’m going to use whatvim after is someone’s knowledge on what bottom end is best used to create a powerful frankenmotor maybe 160-180 hp. my old Vw engine was 90hp so effectively doubling it. with anything above 200hp I guess id rip my gearbox to shreds thanks
Hello can someone please point me in the direction of which ej25 engine block will work best for a frankenmotor?? ive read Ej25d which I’m pretty sure is from a dohc engine?? i read 1999 because of piston size and rod length. Do these have a different crank?? is there a specific year or model that would create the higher compression required with the frankenmotor. any engine block years to avoid?? would a new ej25 2005 or older up be any better and why?? yup I’m a bit confused as to which is the best choice. im running an old ej22 wiring system from a 1992 legacy. OBD1 twin port ej22 heads thanks for your time anthony
Ok had another look. Engine back out. Looks like the left hand head has jammed solid. The timing belt is all torn and wedged under the belt guide. The inside of the rocker cover one side looks very dry and I'm suspecting has had no oil. Not too sure though. Need to try and find the cause and hope no internal damage. Any thoughts thx
Ok Things moved on but not as I would have liked. Got it all together installed. Running. Wasn't totally convinced all good as tapping noise. Didn't sound right Any way test drive lasted about 30 mins. Then I got towed home Only had time for a quick look. Sounds like no compression so thought timing belt slipped. Engine will turn but doesn't feel right. The cam sprockets on both heads appear to be jammed solid. Maybe I should stick to carpentry ???? Any thoughts?? Thx in advance
Thx The engine the heads came off were from a 1993 liberty or legacy Australian spec. They are twin port though. Ok I've just put the heads back on and timing belt. All the notches lined up etc and seems good. Is it normal to not feel the compression on these engines?? It does stiffen up when turning it over but doesn't feel the same as other engines I've done before just wondering if the hydrolic valves changed anything or it could be in using a 2 foot bar to turn it over with. Just thought it would be harder to turn over. New rings. Pistons and heads reconditioned. Any thoughts Thx in advance
Another question. Possibly a stupid question. As I said I'm doing the frankenmotor thing and have been doing a fair bit of reading. One of the things I've read is that there are 2 types of ej22 heads?? And that only one type will work. The twin port is the one to use apparently. Does the twin port relate to the twin outlet for the exhaust??? As I've never seen an ej22 with a single exhaust outlet. Thx Anthony
