wells01
Everything posted by wells01
  1. I agree but I think it would be best to get the codes as I would be able to start looking in the right area. Many thanks.
  2. Hi thanks for the reply. I tried the fuses but there was no change so i took the dash out. The VDS and ABS bulbs were missing so I replaced them and sure enough the ABS and VDS lights are constantly illuminated. How do I get the codes. Is it via the obdii connector or via the mysterious black/white connector which ive been unable to find. Many thanks
  3. Hi This is my first post so I hope I am doing it correctly. I have a 2000 legacy gx automatic estate. My problem is that the ABS does not operate at all. On startup the Abs does not illuminate but the VDC off lamp does. I have checked fuses #8 and #15 and they are fine. The two relays near the abs unit click when the ignition is turned on. My suspicion is that someone has removed the ABS bulb which I think I need to get the codes to diagnose the problem!! Is there any other way of getting the codes or do I need to strip out the dashboard to check the abs bulb? Many thanks for any suggestions.
