whynot162
Location
sw washington
Vehicles
1999 outback
Recent Profile Visitors
487 profile views
whynot162's Achievements
Member (2/11)
I did not resurface the heads everything actually looked really good as far as I could tell. They checked flat with a flat edge. I will have to get the stuff to do a coolant pressure test. I assume that is what you are talking about. can it be done with the car cold? I cleaned the holes and lubed the threads, used new bolts, and did not have any creaking when tightening it up. compression is good, no bubbles in the overflow tank, and the exhaust does not have a sweet smell. I filled the engine coolant through the upper hose, so I was pretty sure it was full. now I am even questioning that. This is my first subaru, but I have done other head gaskets without problems. will a coolant tester form the auto parts loan program work on this car? or one from Harbor freight?
Long story short, I bought a 99 legacy wagon with a blown head gasket for my daughter. Replaced the HG and repaired the rest of the car. She drove the car for about 3 weeks, then it lost coolant, no heater and overheated. so we put coolant in it and drove it the last 20 miles home. Went to start working on it today and it is full of coolant. Also the compression checked out at 140 to 150 on all cylinders. I am going to go out and put it all back together and start it up and see what happens. I thought it was coming out of the tail pipe when I followed her home that day, but only for a little while. What could be the possible issues? I do not see any coolant under the car either. thanks Doug
so I am looking for a 1999-2004 engine from any subaru, with a 2.2. While I look, I think I will go and get the 2.5 out of the wrecked car in it. I have 2 of these cars, so I will look for an engine, and get ready to change the first one over after the first of the year, or when I have more issues. And I will look for any procedures on this. So the cheap, because I have it, and then the long term is to take both cars to a 2.2? and then the cars should be good for many more years. or decide on something newer. (love no car payments) For some reason I like the look of the 99 better than the newer ones.
I guess I am just scared of the conversion. I hear everyone say how easy it is. but the last time I did a swap that was easy, it was full of the oh, we forgot to tell you problems, and you should have got a engine from a newer than.. car... So being fairly new to these cars, I have a very limited knowledge of what is compatible.. So I think right now, I am better off pulling the engine (2.5) from the wrecked car, moving the timing kit and water pump over to it, and put it in the car without doing much else and seeing if I can get by with that for now. And learn about the swap and what I need so I can do that next, finding all of the things I need so it will work, and I will know what I am getting into.. Neither of the cars are worth a $2500 repair, they are 1999 cars. But it sounds like just doing this again, even with resurfacing the heads will lead to quick failure? I have never heard of filling the pits in the fire ring with filler, nor would I know how to do it. I did not see any pits in the block near the cylinders, but that does not mean that I know what I was looking for. I can swap these and figure out how to fix the one I take out, or prep to go to the 2.2. but I think the car could use more power even with the 2.5.
I did use new bolts and tapped all the threads. I lubed the bolts as well on assembly.I did not go into the pistons etc. Do I guess it is all about not having the heads machined. Now just have to decide what option is the best to get this back on the road, as a reliable daily driver.I did follow the torque sequence on removal as well as install If it has been overheated to the point of warping the heads, will machining them fix them? or are they toast, and need to be replaced? that would mean putting in the other engine. which I am leaning to. But they both have just over 200K on them. .
after putting coolant into the car again, It is also pushing it slowly into the overflow tank. I do not know if the car was overheated before I got it. I assume now that it was, and now I know it has been. Today. Can I pull the engine and transmission together? is there a way to do that and just swap both from one car to another? Is there any test to do to the engine in the wrecked car to be sure it is ok? The pully on one of the cams is broken off, But I think I may have broken that prying the front of the car away from the engine. It has not ran since the wreck
So I got a 99 outback wagon, it had bad head gaskets, blowing water out of the radiator. so I got the car, pulled the engine, did the head gaskets and timing belt set etc. I did not take the heads in, I checked them with a machine straight edge, and feeler gauge. Assembled and it ran for 4 months. Now it is blowing water out of the exhaust so what do I do now? I do have a car with the front crashed, that I hope the engine is good in it. I can either pull and try and fix this engine again, what did I miss? I can just transplant the engine from the wrecked car, I can pull from the wrecked car and do the headgaskets and move the timing set to the other engine, But what did I miss on the 1st time I did this, and will I make the same mistake again? I used felpro gaskets I would prefer not to change to a 2.2 engine. This car is being driven by my daughter who just graduated college. Thanks Doug
