alexbuoy
Everything posted by alexbuoy
Scary. Broke my strut mount as well wheeling the brat this weekend. I believe they were monroe’s
Sjr vs ADF Lift Kits for GL/Loyale
alexbuoy replied to 89GLWarWGN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most older gen subaru people like SJR. I’ve ordered from ADF and SJR and strongly prefer SJR. -
Would you take 250 for the dual range trans. I have a friend in sacramento that can pick up
Production brat lift kit
alexbuoy replied to SgtSparkles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
https://www.sjrlift.com/collections/ea81 -
I made a writeup for an ea81 lift. Let me know what I should add or needs modification. https://docs.google.com/document/d/1tj10tAHy26scnxFRt7JBJs_mHIx_WDRlg1ecVl3HMnE/edit?usp=sharing
Also after some tail lights that are in OK condition or has small cracks for my brat. I have a set or two but it's way to nice to put on. Let me know if you have any leads.
Brats been getting some love as well. I'm building off my existing square tubing front bumper. Made an upper and lower hoop and the skid plate is going to tie into it as well. Bent up a simple rear bumper too. Using 1.75" .120 DOM. I got UELS as well. Prepping for king of the hammers
22e block with 205 heads. New seals all around, killer B pickup, 11mm oil pump, reused t-belt. Got my 04 WRX harness trimmed by SJR just need to start throwing things together.
Picked up a JDM sti 5 speed, EJ22 longblock, and EJ205 complete with bad bottom end. Got the 2.2 and 2.0 torn down the 205 heads will be getting decked friday. Ill also be picking up a 2004 wrx bulkhead, ecu, and pedal assembly friday. He also has DW 2000cc injectors for sale at a decent price. I’m thinking that size is overkill even running e85
I think the tinypic website shut down. Oh well
YES I LOVE MY EJ22S
Well spoob there goes all my pictures. Picked up another EJ22 longblock with significantly less miles. Also will be picking up a JDM sti 5 speed and a blown WRX EJ205 this weekend both for dirt cheap. Pretty set on my motor option now. EJ22 n/a block with EJ205 heads. Gonna be running STOCK internals CR should be high 8’s. And my block is a 96 so supposedly it’s slightly beefier pistons than 97-98. Also going to need a good tune and i’ll be running some corn. I now have a chopped 98 2.2 harness for sale. PM me
Good to know. I always forget ea81 and ea82 axles are different lengths
EJ tailshaft cut length ? In EA81 ??
alexbuoy replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I posted in the other thread i’m sure you saw. Another option is GC automatic driveshaft. My friend used it and he says : The driveshaft is maybe an inch shorter than what would be ideal, but the splines on the slip yoke still have 2-3” of engagement, and the dust cover still overlaps over the seal on the tailhousing. -
I am planning to do a EJ trans swap in my ea82 wagon very soon. My friend has an ej trans in his brat and this is what he wrote : Cvs are hybrids. I put EJ inner joints on the Brat axles. Driveshaft is from a an automatic GC. I made a bracket to hold the carrier bearing. I put the Brat spider gears in a newer 4.11 rear diff so I can run Brat rear axles
Ok found a JDM trans for really cheap locally. Its a JDM import and it looks like it was never put into a car after it was imported. Trans code is TY752VBBAA I put that into all the transmission type searches and it shows up as 4.111 but this dude claims its 3.9. I guess its because he's using a whack website. May pick it up soon if everything goes well. And he only wants $145.
Ok let me rephrase will be doing some occasional launches that's about it. I guess i'm not too hard on trans since my 5 speed dualrange still runs in my brat, and at least for the motor I don't treat it nice. I will be running a completely stock ej22 n/a block 25D heads. I've heard the 22 blocks are quite stout and with proper EM I should be good. Right now i'm leaning towards the JDM 5 speed STI trans. Unfortunately have to convert to hydro clutch, but info on here says a WRX pedal assy will fit with minor modifications. I don't know finding the right trans is such a pain. https://www.ebay.com/itm/JDM-Impreza-WRX-WRX-SA-WRX-STi-MY94-TY752VB3CA-4-111-RATIO-5-Speed-Cable-Trans/183772132719?hash=item2ac9ac356f:g:NtIAAOSw4A5Y1pQ8
Id rather spend a couple hundred more to upgrade than to run an older EJ trans and have it blow up. Auto dismantlers want >$400 for a 3.9. Another big problem is I really can’t find any good used older 5 speeds outside JYs. Every one i’ve found has the occasional popping out of gear/scratching and shot main shaft bearings. Realistically WHP/WTQ wise I don’t ever think ill go past 250/275
My driving habits are kind of rough as I like to shift quick and do occasional launches. Especially with a quicker car i’ll be getting on the gas all the time. I also won’t be running a crazy stage 3 clutch, i’ve heard they shorten the life of your trans. The US gets the worst trannies. The only H6 manuals I know here are swapped.
That chart has been very helpful. I found a 94-95 JDM STI 5 speed on ebay with the same ratios as your transmission. Problem is it’s hydraulic clutch. Most if not all JDM trans i’m seeing are the same. I don’t think you can convert those trannies from hydro to cable since all those trans don’t have the fork ball pivot ? correct me if i’m wrong. Id prefer if I didn’t have to convert my loyale to hydro clutch, but if I have to I will.
