alexbuoy
Everything posted by alexbuoy
It would be best either finding a partout or buying a parts car. There is a writeup floating somewhere here by Numbchux. I would recommend SJR for the harness, lift and adapter plate. Flywheel you can use a dremel tool with a carbide bit and elongate the holes until it fits the EJ crank. If possible look for a 96 EJ they are non interference and OBDII.
Also picked up a bunch of stuff and a Datsun 720 transfer case from board member czny. I’m excited to see where this goes but it won’t be until the summer till I start planning the divorced tcase
Past couple weeks i’ve just been preparing the car for King if the Hammers. Got almost everything I wanted done. Didn’t get around to a skidplate but I guess just pick good lines. Replaced my master cylinder, tucked my wiring, got a pitch bar mount made, made a poly diff bushing and trans bushings and replaced just about every hose on the engine/car. Should be pretty reliable now. And also i’m working on another front lift. 4.5 inches and i’m going to try a straight cut. Should fix my insane negative camber and rake.
Does anyone know what angle I should cut the front blocks at? It's for a Brat with EA82 front xmember/suspension. I tried 5 degrees but there is still a little negative camber. I'm thinking about cutting it straight with no angle next. Also would my axles be OK with a 5 inch front lift and a 4 inch subframe drop? With aftermarket EA82 front axles. Thanks
1. Depends. I love my EA81 and EA82 platform, but I wouldn't mind anything with an H6 or an EJ22. I shy away from everything else. 2. Manual all day. Only time i've heard someone prefer a CVT is on the trails, guess they don't know the power of the dual range haha. 3. I like toyotas and hondas. Pretty reliable although our 4runner blew a headgasket at only 270K miles. Really depends what you want to do. If it's a DD subaru isn't bad. Especially if you need the AWD. If you want to trail it Tacomas and 4Runners all day.
Sold for $46,198!! Guess we better stockpile our EA81's and EA82's because i've got a feeling they are the next to go up in price.
Got the loyale out of the garage finally. Under it's own power too. I'm out of school and work for the rest of the year so hopefully I can pay more attention to my subarus. I want to get the Brat reliably running and trail worthy soon. I also will have 4WD for the brat again soon.
Really haven't done much to the brat recently nor do I really drive it anymore. About a month ago I had two coolant hoses fail. Replaced a majority of the coolant hoses so it should be good to go. Still need to burp the coolant system. Need to fix my heat controls asap as it's getting cold here in southern california lol.
Edit- Ok how about Eugene OR Mechanic?
alexbuoy replied to coolhandluke's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My friend works at a shop in Vacaville. might be a drive for you but if you want shoot me a message and I can link you up with him. He had a loyale very similar to yours, 2 inch lift, dualrange, etc. -
Alternator bracket mounting
alexbuoy replied to MWLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’ve never seen a non a/c ea82 alternator bracket like that. My alternator bracket was off an 88 GL. I don’t even think that bracket is for EA81 either -
Here is the alternator setup on my EA82 without A/C. I think there are two brackets? Did you just rip out A/C or never had A/C? -
This was the first weekend I was really able to hit some dirt in the Brat. I finally got the power steering in too . The PS took a dump driving home but I haven't been able to diagnose it. Drove 1.5 hours to Gorman, CA to test it out. Something is clunking in my front end extremely bad now, but I was going pretty hard hitting big dips and bouncing the rev limiter. Here is my favorite shot from the trip Me with my friend Jason and his 1982 Brat. Of course there had to be carnage. My temperature gauge broke on the way. And worse my rear stub axle shaft sheared in half. Took me like 30 minutes to put a rear axle in and 5 minutes later snapped the stub axle shaft. The day after Gorman I went to Subiefest out in Arcadia, California. Shame I don't take photos, I always forget. Thank you to Pedro for this shot of me rolling in Very weak selection of old school subarus out there. I think in total there were 4 Brats, 1 Loyale, 1 GL, and 1 XT6. That was the first time i've seen an xt6 and that thing was cool. Should've taken a picture of it. 83 Subaru GL, 300k+ miles AND it drove from Reno, Nevada down to Los Angeles. That is far as f!! 91? Loyale. No lift, 27's. Possibly one of my favorite cars there Love that fitment
The tube chassis is about 90% done now. I'd like to eventually link the front/rear bumpers and the shock hoops to it. And I finally welded in my drivers side rock sliders. It's kind of crooked and annoying, but oh well, can't do anything about it now. The passenger side turned out amazing though. And here is a crappy picture of my tube chassis. I'll need to get a better picture eventually.
Hopefully I will have floorpans that are solid and not have any gaping holes in it. I've got almost an entire rust free floorpan that I need to weld in, I just need to find the time. People always get tripped up when they see the floorpan behind the seats are just a gaping hole. But the mounts for the drivers seat I welded in reinforcements... so I got that going for the car haha.
79-84 Wagons vs 85-94? Wagons
alexbuoy replied to aem0512's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Loyale 4WD pushbutton just has FWD and 4WD hi. The GL dualrange have FWD, 4WD hi, and 4WD lo. if you’re trailing it upgrade to dualrange -
Thanks! Unfortunately I do not have a tube bender. The tube chassis was done with some pretty unconventional angles but should work. The sliders were for a toyota but were cut down to make it work. The pictures don’t do it justice how rusty it is. I’m still driving with half my floor pans missing haha.
About a week ago I picked up some mint seats to replace my worn, torn seats. I was able to score 2 rear axles, 2 seats, headlight bezels from a 1980 hatch, and an antenna for $110 from the Junkyard. That antenna was hard to find, I think only 3 years were made with it being on the drivers side. And I was finally able to wrap up my ditch lights. Made with 1/8 steel, no drilling or modifications required. I'm planning to take a trip to Gorman this Friday and go to Subiefest on the 21st. After my test on Tuesday i'll be trying to wrap up my tube chassis, sliders, and make some more hybrid rear axles. The tube chassis is almost complete, I just need to fully finish welding a couple spots. The passenger side sliders are completely welded on and they look bad @ss. The drivers side still needs tubing to be notched and welded on.
1982 Subaru Brat EA82 Front crossmember/suspension 4/3 Inch lift 29" mud terrains 5 Speed Dual Range EJ22 Welded Rear diff Same rear shock setup as OP
Simple writeup on how to extend your radius rods. Works on EA82 and EA82. Let me know if there should be anything added to the file. Also let me know if the link works. https://docs.google.com/document/d/1fkV-qKOUSRcKx4W61NXp-KiIdVVysgXihl84dWohwg8/edit?usp=sharing
