drewd
Location
Freehold
drewd's Achievements
Member (2/11)
10
Stock Potenzas...they have 60k on em. I'm starting to look for tires, but i think i can get another 15-20k on these...they're in pretty good shape. I never measured the depth of the treads, but i can tell you they're far from being bald. Still no answer to the question, though...why was the soob jerking while hydroplaning?
While driving home last night in the pouring rain the soob started to feel jerky when the rain got heavy...doing about 60 on the highway at times. I know i was hydroplaning at that speed and i could feel it...she stuttered for a bit and then it was ok...very weird. So, what's going on and is this normal? '03 H6 with 60k, no problems otherwise.
I've got an '03 H6, about to roll 60k with no major issues to speak of. I had a bad idler pulley about 30k ago that sounds like it needs to be replaced again soon. Other than that, it has been solid. I did hear piston slap on my engine two years ago, but that's because it was about 2 degrees outside when i started my car early in the morning during winter...clack clack clack clack clack clack clack clack....
I have the same problem with my OBW. Every time i drive through wet snow it sticks to the wheel wells...i got screwed one night, drove home in the wet stuff and the temps dropped like a stone overnight and froze the snow. I took it out for a drive and the tires would hit the ice everytime i drove over a bump. I had to use a chisel to get the ice out. The best thing to do is brush out the snow after driving, especially if you know it'll freeze overnight.
Here's my situation... I needed brakes done on all 4 wheels of my '03 outback (warranty expired)...got it done at the stealership and they turned the rotors for me...this was back in early October and a little over 3 thousand miles ago. In November, the cold weather starts to set in in the mid-Atlantic states and i start to hear the brakes screaching in the morning backing out of my driveway. Once i'm driving it, the noise disappears, even in reverse (after the car warms up). I did some research on this site and i think i found the problem...there was a bulletin about adding shims to the brake pads in all outback's prior to '02 because some customers were complaining of noises on cold mornings. There was also a chart with the updated OEM parts and the part numbers that they would be replacing. I checked the brake job invoice, and sure enough, the part numbers were nearly identical to the "old" OEM parts that came from the bulletin board. Which means, i got the brakes without the shims. Took it back to the dealer today for a scheduled oil change and told them to investigate my problem, gave the mechanic a copy of the bulletin i found on this site. I knew they would fight it, the guy says he can't reproduce the noise and that i need to leave it there overnight so they can check it in the am. They don't want to replace my brakes as per the bulletin because it may not be the problem and they'd lose money on the parts if that's the case. He said he'd give me a rental while they check it out, but quite honestly, i don't have the time to play games with the dealership. It's pretty obvious what the problem is, and i don't see the point in trying to reproduce the noise, anyway. Would appreciate your opinion on the matter, should i play games with the stealership and try to get the correct parts, or just leave everything alone and deal with a minor annoyance? No other problems with my brakes, by the way, no noises after driving for a while, only in reverse on cold mornings.
H6 Engine
drewd replied to LuckyStrike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The plastic is just a cover...keeps some of the grime away from expensive parts like your alternator. I don't think you'll find much on here about the H6's mainly because they're still relatively new, most of what you hear is all positive, though. I've got one and i'm happy with it. Wait about 2 years when most H-6 owners roll 100 Large and then we'll know. -
Dash Noise
drewd replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've heard the same strange noise coming from behind the cd player in my wagon. Sounds like electricity, a low pitched quick buzz sound. I hear it every once in a while but only when i'm in park or idling when the radio isn't turned on. Not sure if it happens while in drive because of the background noise. -
I'm looking at a similar problem my brother is having with his jeep wrangler...low oil pressure at idle and when the engine revs were raised the pressure increased to normal. It could be the oil pump, but you need to get a gauge and check it yourself to be sure it's not the sending unit. That's the first thing to do. If that's ok and the engine has high mileage there's a good chance you need a rebuild because the main bearings wear and excessive clearance causes low oil pressure since the pump has trouble keeping up. I'm no mechanic, so it could very well be a bad oil pump, too.
I have the same car...breaks started sqealing around that mileage, too. The dealer checked the breaks and said i still had 50% left in the fronts...they cleaned the breaks at about 30k and they stopped squealing for a while...just started up again at 43k. Subaru does NOT cover this service under warranty. I think i'm gonna need break pads on the fronts next time i go back to service it. Definitely seems a little early for pads...if you do a search on this board you'll notice quite a few others complaning about the same problem with this model subaru...
