5
Everything posted by Scott in Bellingham
New Product line Im introducing strut spacers in 1/4" increments , first set is 3/4" (20mm) http://www.sjrlift.com/index.php/catalog/lift-kits/0-1-1-2-lift-kit-ej-fits-90-99-detail also new Alloy rear 2000+ 2" shock spacers http://www.sjrlift.com/index.php/catalog/lift-kits/0-2-lift-kit-2000-252016-06-24-17-42-53-detail
we want to see this !!!
Walker Valley Trip SJR June 2016
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
That may be better as the wife reminded me about a family commitment on the 18 th -
What all do I need for a 3" list on my 2001 Subaru Forester?
Scott in Bellingham replied to mookiex4's topic in Suspension
I feel 3" is to much on a all suspension lift, 2" max , you need a complete lift kit for 3" like this one http://www.sjrlift.com/index.php/catalog/lift-kits/0-4-lift-kit-ej-fits-90-99-detail -
Saturday June 18 I'm looking to hit walker again , had great time last Saturday and want to do it again, Basic car needs lift, tires, locked rear diff, you will need a Discovery pass , who wants in?
Walker Valley memorial weekend 2016 SJR
great day heres a pic https://www.facebook.com/photo.php?fbid=2024186584473566&l=5114f7332a -
Rained so were goin today be there before noon -
T-case lift FAQ (transfer case questions / answers)
Scott in Bellingham replied to bushbasher's topic in Off Road
Use a 720 nissan t case or a Sammy behind the stock dr many have done it works well -
Lookin at hitting walker either Friday or Saturday this weekend anyone want to go?
This fell out of my gl!
Scott in Bellingham replied to Stihlman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From your cat, it can clog up he exhaust and run powerless untill unclogged -
your in Auburn? If you drive up to Bellingham ill get it right as I didn't have a 4x4 just a older fwd to look at Scott
M/T. 205/65/15 recap
Scott in Bellingham replied to superpoo93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a set of recaps same pattern 14" rim I run, good tires for he mud -
Ea 2 Ej wiring
Scott in Bellingham replied to ennbenn72's topic in Old Gen.: 80's GL/DL/XT/Loyales...
With a EJ swap you only need to add the EJ system to run the engine, all the stock wiring is left in the car just tapped into to run the new engine and it's ECU -
I like the Maxxis bighorns, not the most aggressive MT but good all around tire 29" is about max with stock outback strut
having worked in a Auto Body shop simple answer is yes the issue is how to get a hold of the spot that needs pulled out and how to hold the rest of the car from moving and getting bent , in the shop we had a framework that would clamp to the underside of the car at the pinch weld seams, it was always a issue on how to grab the bent sheetmetal, it almost always got mangled , usually a few cuts and a pull then rework the cuts and area and add a new part would fix it
Hovercraft powered by EA82 needs more power
Scott in Bellingham replied to xnavyguy69's topic in Subaru Transplants
Your best bang for the buck would to find a complete doner car with good running engine, then you will have all the wiring and ecu, The intake exhaust and cooling , what type of drive trans system will you run? -
Ej Swap Grinding in 1 3 and 5
Scott in Bellingham replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could be the linkage rubbing the driveline
