5
Everything posted by Scott in Bellingham
Off Road Bar 1995 Legacy L Wagon
Scott in Bellingham replied to catunderthestars's topic in Products for your Subaru
I can make one, what would you like? -
Lower gear or transfer case options
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
I can help with that -
newrider3 that's cool Im guessing you welded the center diff? -
I got myself a 99 outback with a 5 speed, I pull a trailer with it and it just doesn't have a low enuf gear to pull up my steep driveway loaded down, if I had a lower gear I could do it , I'm not against lifting it and adding a transfer case but the 5 speeds a AWD so I would need to lock the center diff, I could swap in a Dualrange , I would like to lift it 3-6" and add another front diff but to do a 2nd front diff I would need 8" I have a 720 Nissan transfer case and also a Sammy t case anyway just trying to get some discussion , if I could mount up a normal transmission not a transaxle there might be room for a second diff up front with a 5" lift or maybe even go with a diff off to the side , anyway let's talk options
4000lbs ATV Winch for Loyale
Scott in Bellingham replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm running a similar one, mines rated at 4500. Get a pulley so you can double the pulling power , mine has done everything I needed it to do, your not going to pull out a stuck pickup with it but it will pull your rig, remember the more cable you have pulled out the more powerful your winch will be -
What would be the ultimate off road Subaru?
Scott in Bellingham replied to pontoontodd's topic in Off Road
EA82 Dualrange 85-88 EJ22 EA82 or newer axles Body is preference, lighter the better -
Swapping front drivetrain.
Scott in Bellingham replied to wallaby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes leave it complete, unbolt from the body, raise the body up and rollout the whole front drive unit, it's a lot simpler and quicker, don't even unhook the y pipe -
Look what I found
Scott in Bellingham replied to angerthis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that's Kenny Nichols old car -
You will like those tires, that's what I run
EJ22 swap transmission question..
Scott in Bellingham replied to ragingbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your stock 4speed that's in the Brat will work , you can swap it out later, the GL Dualrange is what you want -
Same parts on 86-89 leone?
Scott in Bellingham replied to Starlite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In the USA , all the suspension and drive is the same , the wiring and accessories may be different -
Www.sjrlift.com
I used a stock harness and trimmed most the stuff off it didn't need i left the light, horn, dash , wires,
- 1 reply
- 1
been on the trails a couple times, thing goze awesome love the power to weight good clearance and tight turning radius , best Subaru Ive ever wheeled offroad https://scontent-sjc2-1.xx.fbcdn.net/hphotos-xfl1/v/t1.0-9/12046909_1894695534089339_387143319797217367_n.jpg?oh=c4cadd9cda1deb20cdd7d13d89459175&oe=569DA592
looks like you have a 88 DL wagon, if so 2" max is what Id go over stock on the axle lift angle, on the lift kits I make and sell they are 1" over stock on the EA82 and EJ cars and 0" over stock on the older EA81 cars, the older EA81 axles just don't hold up to much over stock, the EA82 axles are stronger with more bell length for more axle movement if you go with a 27" tall tire I suggest a 4" lift, on my lifts (SJR) its 4" at the struts and 3" at the engine suspension and diffs so its a 3" body lift with 1" suspension lift, no need for different axles , turning radius wont be lost as long as your tires don't hit the body, narrow tires with close to stock rim setback will help , hope this helps and keep us informed on your build Scott
Good Times https://scontent-sea1-1.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/12038437_1894695857422640_584284172288007465_n.jpg?oh=ba481b7d6410717f509638af7a0913c2&oe=56A040E0 https://scontent-sea1-1.xx.fbcdn.net/hphotos-xfl1/v/t1.0-9/12046909_1894695534089339_387143319797217367_n.jpg?oh=c4cadd9cda1deb20cdd7d13d89459175&oe=569DA592 https://scontent-sea1-1.xx.fbcdn.net/hphotos-xtl1/v/t1.0-9/12039582_1894695710755988_2627329099386108942_n.jpg?oh=9289bee3f19399ba13b10495d2d75051&oe=5695DC81
Got it, it was the cam sensor all along, thanks guys , it wouldn't start, I installed a different cam sensor and it ran then I reinstalled the original and again no start so installed the new one and it runs good now, it's the engine in my new Buggy, I ran it all day yesterday with no starting issues, so thanks again everyone , you guys are great!
I've narrowed it down to a spark issue, I ran it today then let it sit ,it continued to start up every time every few minutes till it sat about a hour, then no start, checked with a extra plug no spark, I changed out the cam sensor and it started, I then reinstalled the old cam sensor and it also started and ran fine, so now I'm still not sure, but it is a ignition spark issue
