5
Everything posted by Scott in Bellingham
EA flywheel drilled to EJ pattern??
Scott in Bellingham replied to Scott in Bellingham's topic in Subaru Retrofitting
me too has anyone done that? -
27" tires is to EA82 as XX" tires are to EJ22
Scott in Bellingham replied to Uberoo's topic in Off Road
split the hi-low so you can run it low 2wd thats what Ive done -
Im not to interested in getting a ticket, will have to check out that garden edgeing
looks good... come join us on the 27th at walker valley heres the link http://www.ultimatesubaru.org/forum/showpost.php?p=547746&postcount=1 ______________________________________________________________ 87 GL Subaru 6"lift , 30" Hankooks M/T My online Subaru lift store http://www.sjrlift.com Videos of my Soobie offroad http://www.loghomefamily.org/subaru/
Ok Im putting a EJ2.2 into a 87 EA car on drilling the flywheel do I make new holes in between the old holes or do I redrill the new pattern over the old pattern using like half the hole so the finished holes are somewhat egg shaped???
I got my 30x9.50 Kooks and now I need some fender flares what should I go with? any ideas or pics , its on a EA82 with 6" lift needs a little trimmin thanks
........................Buy a Jeep ........................... HHHHHaaaaaaaaaaaaaaaaaa :banana:
IMMEDIATE ATTENTION NEEDED, ORV opinion poll-time sensitive
Scott in Bellingham replied to chazmataz's topic in Off Road
I clicked yes -
are Impreza axles longer then EA82 axles ? which way is your camber goofed up, looking at the front, \.... / or /.... \
Noah some questions what car model what transaxle what axles what struts what lift how high what knuckles
Walker Valley January 2007 Trip NW WA SJR
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
Andy you in on this? you should come, I have a extra diff if you need a locker -
Shop/Club night Bellingham Offroaders
tomarro Wed the 3rd Jan working on the front diff crossmember for ea82 T-case conversion -
yes its the guy that has it in his album Adam from Oregon
Nice Picture? -
next month I will start my T-case conversion on my old red car and will detail it with pictures and stuff in a new thread , so far I have the car, have a Nissan t-case and have the 30" Kooks to install
i have a set i will sell
that would be great, what mods does he have on his Sammy? -
if you raise the engine 2" from stock you could squeeze the 6" , the transfercase will be hangimg down low unless you cut a hole in the floor and stuck it up in the cab a bit
stock 3.9 front and rear those are wore out 31 x 13.5 swampers on the back , in the sand your spinn so much the ratio didnt matter, it was a test, the car went better with the 215/75-15 snow tires all around, only issue I had was heating up , only had one fan on the rad, highly recomend 2 fans and a override switch if your playin in the sand
7-10 if you have a project your welcome to come at 6 and leave at 1 A.M. treats are always welcome -
Dylan bring over the Subaru emblem painting magnet stencel I want to put one on my hood thanks -
so far it looks like Me Ro\\ie and Dylan have committed -
sounds like you need a 4" block , maybe stick a chunk of 4" wood in there and after the engines all hooked if you like how it looks go 4"
Wow.... Land Rovers are pretty hardcore
Scott in Bellingham replied to SakoTGrimes's topic in Off Road
That second video slideshow I reconized most of the cars from this board my old red car was even in there a few times , :brow:
