Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. split the hi-low so you can run it low 2wd thats what Ive done
  2. Im not to interested in getting a ticket, will have to check out that garden edgeing
  3. looks good... come join us on the 27th at walker valley heres the link http://www.ultimatesubaru.org/forum/showpost.php?p=547746&postcount=1 ______________________________________________________________ 87 GL Subaru 6"lift , 30" Hankooks M/T My online Subaru lift store http://www.sjrlift.com Videos of my Soobie offroad http://www.loghomefamily.org/subaru/
  4. Ok Im putting a EJ2.2 into a 87 EA car on drilling the flywheel do I make new holes in between the old holes or do I redrill the new pattern over the old pattern using like half the hole so the finished holes are somewhat egg shaped???
  5. I got my 30x9.50 Kooks and now I need some fender flares what should I go with? any ideas or pics , its on a EA82 with 6" lift needs a little trimmin thanks
  6. ........................Buy a Jeep ........................... HHHHHaaaaaaaaaaaaaaaaaa :banana:
  7. are Impreza axles longer then EA82 axles ? which way is your camber goofed up, looking at the front, \.... / or /.... \
  8. Noah some questions what car model what transaxle what axles what struts what lift how high what knuckles
  9. Andy you in on this? you should come, I have a extra diff if you need a locker
  10. tomarro Wed the 3rd Jan working on the front diff crossmember for ea82 T-case conversion
  11. yes its the guy that has it in his album Adam from Oregon
  12. next month I will start my T-case conversion on my old red car and will detail it with pictures and stuff in a new thread , so far I have the car, have a Nissan t-case and have the 30" Kooks to install
  13. that would be great, what mods does he have on his Sammy?
  14. if you raise the engine 2" from stock you could squeeze the 6" , the transfercase will be hangimg down low unless you cut a hole in the floor and stuck it up in the cab a bit
  15. stock 3.9 front and rear those are wore out 31 x 13.5 swampers on the back , in the sand your spinn so much the ratio didnt matter, it was a test, the car went better with the 215/75-15 snow tires all around, only issue I had was heating up , only had one fan on the rad, highly recomend 2 fans and a override switch if your playin in the sand
  16. 7-10 if you have a project your welcome to come at 6 and leave at 1 A.M. treats are always welcome
  17. Dylan bring over the Subaru emblem painting magnet stencel I want to put one on my hood thanks
  18. so far it looks like Me Ro\\ie and Dylan have committed
  19. sounds like you need a 4" block , maybe stick a chunk of 4" wood in there and after the engines all hooked if you like how it looks go 4"
  20. That second video slideshow I reconized most of the cars from this board my old red car was even in there a few times , :brow:
