5
Everything posted by Scott in Bellingham
SJR Ultimate offroader project
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
we finally got started on the project in the shop heres what it looks like after a afternoon of choppin thanks Clayton for the help took some measurements of the ranger tranny , looks pretty long, reconsidering , loooking at the old Jeep tranny/transfercase, T-90 , its pretty compact. going to look at a set of tires this week they are 30 x 9.5 BFG M/T looks like move front axle ahead 6-7 inches,this will allow the diff punkin to slip up were the stock engine crossmember was, extend rear 10" , so finished wheeelbase 4" short of stock. thinking of installing airshocks in the rear to assist the stock shocks as they will now be 1/3 way up the swingarm , also maybe convert the stock air conditioner pump into a air compressor to have on board air and valves on the dash to control the shocks from drivers seat -
note to self WAS WRONG... real problem pics inside... blah
Scott in Bellingham replied to scrap487's topic in Off Road
on a stock ea82 max camber is 2.5 degree ( I know its a ea81 ) -
just go wheelin it will work. heres what mine looks like , the cross member is dropped 2 " and the struts 3-1/2 " so it has a little more camber then stock ,also the higher you go and the larger the tire it just looks more noticable , remember your building this to improve offroad proformence , it will handle worse on the freeway then it did in stock form, -
Thanks Rollie!!
Scott in Bellingham replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
not sure on year , it seem lancruiser shocks work on a 3 -4" lift
Bellingham, WA subies
Scott in Bellingham replied to mortimc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
he got a few tranny mts from me -
im here -
Reno Area Wrenchfest??
Scott in Bellingham replied to Jibs's topic in Meet n' Greet. Your USMB Welcome Center
I'll be right over -
Walker Valley Run Jan 14th
Scott in Bellingham replied to one eye's topic in Meet n' Greet. Your USMB Welcome Center
adding forgot colateral damage this is what happens when you stand behind a wheel thats spinning in the rocks , I was helping push 1 eyes brat and it shot a rock at my leg , looks bad but its ok , I didnt even have a first aid kit ( next time will) -
the nut , washer , and rubber snubber had fallen off the pas side radius rod , nothing broke or bent , did discover a few good scratches and gouges under the car -
this is what we forund we got it done last night 4 of us ganged up on it check out the purple heat distortion, wheres the fiber? heres why it wouldnt release , and the p plate fingers in/out I want to thank all the guys for the help , it drove great on the way to work today , next time we go wheelin ill have to be nicer to it
well after driving 1/2 the week with no release on the clutch, starting off on the starter in gear shifting grinding on the fly tonight I will be dropping the dual range fixing the problem , anyone interested in coming by is welcome , well also be looking at a ea81 hatch and make a battle plan to lift it, we should look at the turbo car and start stripin it for the sawzall surgery to take place to , maybe we should make wed evenings shop/meeting night and make plans for the next trail run for the end of febuary
I thought I would give you all a update on the project heres my current thoughts as they keep evolving EA82 turbo car (got one in the shop ) shortened 20" in the middle making one door access , move rear axle back a bit , keeping stock swing arm pivot up high , and extending swingarm down and back, keep rear shock in stock placment , add a second set next to them , with the lengthened swingarm and the stock shock placement this will give it more travel in the rear, up front move the front axle ahead 4-8 " keeping stock radius pivot up high or just fab up some new ones with new pivot points, wheelbase should end up 4-8" short of stock, 6-8" lift, convert ford ranger 4x4 transmission into a combo transfercase plus lots of extra low gears, this will be behind the stock soob 5 speed dual range, run 30" tires, heres a computer generated pic: -
sounds more like green with moss:D maybe next time out, hope to see you on the trail soon SJR -
got a bunch of video , just dont know how to post it for ye all , damage report 1 eye broke a front drivers axle he just installed the night befor I cooked my clutch , it was working just fine untill on the way home on normal roads the release mech gave out , its not slipping you just cant release it , you push it in and theres a werring sound the hatch broke a front turn signal and grill, we all had a great time , the new car is awesome , couldnt of went were we went without the welded diff looking forward to next month , one of the guys mentioned a spot out near Hamilton I think skagit area -
thanx for the car beegeer need to start planning next months trip heres some pix http://www.ultimatesubaru.org/photos/showgallery.php?cat=801&ppuser=&page=1 -
I will be there
