5
Everything posted by Scott in Bellingham
in my 'Ultimate Offroader Project' I am considering running a second transmision out of a Ranger/BroncoII complete with transfercase this would give me a 2.74 tranfer ratio, 3.77 first gear ratio in the bronco trans with a final crawl ratio of 220 to do this I will need to convert the front of the Bronco trans from a splined clutch shaft to a yoke with a u-joint , if this is doable it should work awesome behind the Turbo EA82 220CR is ten times slower then stock 22CR
Tranfercase rigs- what tire you running, how big?
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
would you go with that tire size again? I really like your Hatch, looked at it many times is that a 8" lift? -
which axle usually breaks? and what kind of increased angle over stock are you running front and rear -
WCSS8 Where will it be?
Scott in Bellingham replied to Scott in Bellingham's topic in Meet n' Greet. Your USMB Welcome Center
I would like to see some offroad compition of some type, ( not to far from home) something we can take our vehicles to the limit against other soobie nuts ( I really enjoyed last years show, good job guys) the highlight was going offroad with others , also met a few nice guys from my area and have built a relation with them , sorry I missed the AA jump:) -
I would run the 2 x 3 tubing alongside the drop down mounts as to keep the frame tubing one continuous peice, instead of multiple peices which joints have a acces hole in them, in that way the frame would be a stand alone structure and not count on the body for strength, show us Pics as you go along this is interesting Scott
I am in the process of designing a EA82 with added transfercase for lower gears, the question comes up which tire and size should I run? at first I thought 31 or 32 maybe the Super Swamper TSL 32 / 9.5 x 15 , what are you guys running on your transfercase rigs? I have heard the rear stubs out of the diff like to break , what else is a week link?
Allied Armament Super Christmas Group buy
Scott in Bellingham replied to Shadyirishmen's topic in Products for your Subaru
James I like those Bumpers, I could test them for you !, Scott -
walker valley is open
Scott in Bellingham replied to zed wolf's topic in Meet n' Greet. Your USMB Welcome Center
thats good to know therea few of us going out there mid january -
just a thought does this airplane redrive reverse the direction , or keep it normal ?
I could help with the machine work
your right
go for it
Ive been looking at some of the redrives mostly the belt type , I think it has potentual, one drawback is its one gear not a hi or low
Reveal time: From the Phantom R&D Labs
Scott in Bellingham replied to Adam N.D.J.'s topic in Off Road
Adam if you need any help ( machine work, welding etc. CAD drawing ) I will volunter myself and equiptment Scott -
you are correct,. that said if someone wanted the rear axle moved back I could fab up a custom lift with your specs: of lift, increased axle angle and axle placement also you can choose which componants you want on your lift which will give different results, say you want high clearance , then you would want to keep the rear cross tube and diff up high which would resolt in the swing arm swinging down causing a clearance issue at front of tire, now if want to keep everything at stock geometry the you would lower every part equally , this will keep the wheels centered .also it may be possible to put a spacer between the u-joint flange and driveline to prevent having a custom driveline built
heres a few I have had no faliure to date , pictured is the compopnants for a 6" lift , the 3-1/2" lift has less parts
Ratio of running vs. non-running subarus
Scott in Bellingham replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
85 hatch junk 85 ea82 wagon chopped up for pattern making 88 wagon lifted runs 91 loyale cooked engine 88 turbo wagon runs , may become the ultimate offroader 87 ea82 wagon stock daily driver 90 Lagacy wagon fires , working on this one 7 total 3 run 4 dead 2 others at my place but they are not mine -
the spare 15 rim is made of thinner material , also it has no bead ridge that helps lock the tire onto the rim
Go Rollie Go !!!!
good luck, your not the first guy who thought this would be a great idea, , you would only need one with a locker, what most guys do is remove a axle for street driving, takes a few minutes and 2 roll pin removale
maybe it could be a Creepie Crawler
