5
Everything posted by Scott in Bellingham
I know its a short run.... but.....
Scott in Bellingham replied to xoomer's topic in Meet n' Greet. Your USMB Welcome Center
Im near Bellingham check in Scott -
Any Extreme off-road Subies out there?
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
bobbed = to shorten or modify say the rear section of the body to give you a better angle against a hill or a tree its common on the toyota pickups around here to have a shortened bed -
Any extreme offroad subies out there? not your normal 3 or 4" lift and tires , but custom stuff like more articulation, more travel, lower gears, rollcages etheir inside or exoskeliton , modified body , bobbed tail and nose ???please post links or pics here
2" tall in picture , also have 1" tall or can stack them up to get 3" or 4"
here it is
I run a Uniden PC 33 , with a 9' fiberglass wip on a spring, I like the 9' antenna as in the dunes I can put a flag on it, the wire between the radio and antenna was set up by a hamm CB radio guy I dont remember the length but its supose to be a certain length , ( longer then you need) for best proformance, I wish I had a PA with it, its great out on the trails, protect a solid mt as it could brake from branches
Lift kit options?
Scott in Bellingham replied to cmiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
currently working on a 4" lift will be avalible soon , presently offering a 6" lift, check out my site http://www.sjrlift.com/product_info.php?cPath=22&products_id=42 Scott -
What it should of looked like.
Scott in Bellingham replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
once I am tooled up for a 3" or 4 " hope to keep the kit under $400 havent done one yet been working on the EA82 details if I do Uncools Brat I will know whats involved
are these cars stock . do they come from the factory like this? or is a ute a custom one off -
Clutch ? we will do it the same time as lift
Bring it over we will get that Brat lifted
Bring me a car and I will make a brat out of it I love cutting up cars and modifiing them. the sawzall is one of my favorite tools -
what is a Trayback I am from the USA not fimiliare with that term Scott -
Lower gears, using stock drive & 31" tires ?
if you need it yes / get all the drive lines while your at it / I dont know the years but I know some years are more desirable then others Scott -
Yet another northfork run!
Scott in Bellingham replied to uncoolperson's topic in Meet n' Greet. Your USMB Welcome Center
how did it go? who all showed up? what all did you do? -
I enjoyed your video , it would be cool to have lots of cash and bring my car over there and go on a run looks like a blast Scott
you would like a shim block for the front of the diff?, how tall would you like it? , I (SJRLIFT) have plans to make a block to go between the front of diff and the 4 bolt plate that has the 4 bolts welded to it , to install the block it would require those 4 bolts removed, (grind the weld) install the block and 4 new longer bolts, I would recomend putting the bolts in with the nuts up to to make it smoother underneath. I was thinking of making 2" spacer first, what height would you like?
will be leaving town on Saturday then staying at my sisters then we will all go out to the dunes on monday then monday evening have dinner at pacific city and then stay at the Inn at Pacific City monday night play some more on tuesday then head home who wants to meet up? Scott will have CB on channel 2 just give me a shout
explain this what do you mean? -
what do I think, fiberglass is very strong, it doesnt like impacts as it doesnt have much give it will definatly waterproof the underside , the draw back with this is that it will also hold water on top so if any moisture gets through from the top side it will do a good job of holding that moisture against the metal your trying to protect,water runs down hill, also when your driving down the freeway in the rain at 70 mph water seems to get into every crack end crease it can, I dont have a answear for the rust, just try to protect it from moisture, your sheet metal will want to bend and flex were glass will crack and will want to go back, moisture is OK if it has a chance to leave and dry out
