5
Everything posted by Scott in Bellingham
I'd like to try to make a side by side buggy.
Scott in Bellingham replied to utcoyotehunter's topic in Off Road
I have no plans , just experience, someone proficient in welding and fabricating in light steel , as you will need to weld to sheetmetal to do it strong, I have done this and can assist -
Lifting the front of 84 wagon question
Scott in Bellingham replied to Gwywnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2" you will also want to lower the engine crossmember as those EA81 axles don't hold up under all that lift, I can make the parts for you -
Wheel Adapter 86 Brat
Scott in Bellingham replied to Bar D_Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
those look nice, I can redrill your original hubs with that pattern heres my link www.sjrlift.com under Misc -
Ted hows your car equipt ?
1995 Legacy Wagon Offroad Mod Tips Needed
Scott in Bellingham replied to SubaruNOOBaru's topic in Off Road
outback or forester struts will give you the clearance you need for bigger tires -
Scored a lift kit the other day...
Scott in Bellingham replied to d8usti5n's topic in Historic Subaru Forum: 50's thru 70's
I do sell the EA71 kit for the 1st gens its just not posted at my store -
I may be up to that
you can buy my buggy -
10 + years ago I sat in the pilots seat in the Spruce Goose, they had just set it up and my Father had helped work on it and he got us in , cool history
thanks for n sharin, let me know next time you go out, Im itchin to go
Most all my builds have been around the EA82 body format, I have patterns and access to a lot of stuck, what specifically would you need or want, PM or Email may be a better way to do this , my email is sjrwa@yahoo.com -
I can build and or provide you with what you want and need, Ive made a few buggy/modified subarus , I can do it all or just provide some parts and advice or anywhere in between heres a link to some pictures https://www.facebook.com/media/set/?set=a.1694996414059253.1073741841.100006467321842&type=1&l=af9cb242d3 -
the EJ-EA adapter I sell weighs less then 7 Lbs, its 1/2" Steel
plastics ok ,I don't have a recommendation on type , on the upper studs , do the welded together studs so the plastic is ONLY under compression
Id start with a 87-88 , it will be fuel injected and have the 3.9 Dualrange -
Homemade Transmission Crossmember
Scott in Bellingham replied to Jabbott126's topic in Subaru Retrofitting
I used a 1 x 2 , this was on a EJ car -
Starting the journey to find a Brat.
Scott in Bellingham replied to Seventy7's topic in Historic Subaru Forum: 50's thru 70's
where you located?
