5
Everything posted by Scott in Bellingham
swaping an 82wagon with a 81engine
Scott in Bellingham replied to felipeascui's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA81 is good engine change out the fuel pump and run it -
78 brat engine swap ideas please help
Scott in Bellingham replied to YaBoyKingsley's topic in Subaru Transplants
modify the engine bay and slam it in there -
Free Lift Kit for the newer car SJR
Scott in Bellingham replied to Scott in Bellingham's topic in Products for your Subaru
Next is the new legacy -
4inch lift vs 6inch
Scott in Bellingham replied to TheGageinator's topic in Old Gen.: 80's GL/DL/XT/Loyales...
its not the lift height that's hard on axles its the difference in strut extension height compared to the rest of the suspension , -
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
Scott in Bellingham replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm up to this -
4x140 to 5x100 bolt pattern adapters
Scott in Bellingham replied to matts87glsedan's topic in Products for your Subaru
here ya go http://www.sjrlift.com/index.php/catalog/misc/4-x-140-to-5-x-100-wheel-adapters-detail -
Tribeca lift kit ready to sell http://www.sjrlift.com/index.php/catalog/lift-kits/2-tribeca-lift-kit-detail -
I can help ,I could make one similar to the 6" I make. http://www.sjrlift.com/index.php/catalog/lift-kits/0-6-lift-kit-ej-fits-90-99-detail For 31" tires stock Subaru struts may not work as there's not enuf room under spring , 29" is about max, now if you got some rally type smaller diameter springs you could do it without wheel spacers, XT forester struts I think have the most room, not sure how big you can go on them
Dl's anybody?
Scott in Bellingham replied to Greasemonk3y's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's the stuff http://www.sjrlift.com/index.php/catalog/engine-swap-parts -
4inch lift vs 6inch
fronts similar, rear on the 6" the rear suspension tube with swing arms are lowered 4" with the 4" the rear tube is not lowered -
EA to EJ20 for my Loyal Loyale
Scott in Bellingham replied to LittleLoyaleMan's topic in Subaru Retrofitting
you will need EA to EJ adapter plate and redrilled flywheel http://www.sjrlift.com/index.php/catalog/engine-swap-parts/ea-to-ej-swap-kit-detail electrical harness from doner car that fits your engine harness, I can thin that down for you http://www.sjrlift.com/index.php/catalog/engine-swap-parts/engine-wiring-harness-detail plus all the intake and exhaust from same doner car , coupler of pusher fans as theres not enuf room for puller fans -
We need pictures
JDM Dual Range Transaxle (80's)
Scott in Bellingham replied to Brat78's topic in Subaru Retrofitting
The newer EJ trans won't bolt up to your EA Loyale -
Dl's anybody?
You will love the power and never go back, it makes those light cars a hotrod I sell parts and can help with the harness http://www.sjrlift.com/index.php/catalog/engine-swap-parts/ea-to-ej-swap-kit-detail -
Good work, on the stock setup it's solidly mounted at the lower arm , you have a hiem , I'm thinking that lower arm will want to flex now as its only a pressed u shaped steel arm, I've bent a few of those round radius rods in my days wheelin , will be interesting to see how this works out
Big tires destroying cv's? Custom HD axles?
Scott in Bellingham replied to Rallyru's topic in Off Road
Check your moter and transmission mounts, I've seem Brocken mother mounts destroy axles -
Subarute (small truck made from a Subaru wagon)
Scott in Bellingham replied to sawdust_tom's topic in Subaru Retrofitting
a 2000+ Legacy Outback would be a good start Heavy car -
Hope to goto walker valley -
I can build you a lift kit or just the strut, shock extensions, www.sjrlift.com
EA to EJ swap pitch stop mount.
Scott in Bellingham replied to dumptruck's topic in Subaru Retrofitting
The bracket from the ea82 engine will bolt up to those tabs , you will need to lengthen your pitch stopper bar -
What would you guys pay? If I started supplying these same hubs 5x100 XT rears would you do $200 a piece? So $400 for both rears?
