5
Everything posted by Scott in Bellingham
SJR Wheeler Build 90 Legacy Wagon 2013
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
will do got some new rear meats,I had some mismatched tires now I have some 33 1250 BFGs 1/2 tread, its got me excited about workin on it again, will be buyin some tubing for the exo-cage sliders and such, need to get a wood stove for the shop as its been cold out there -
My coupe 6"
Heres Mine
after I fiure this out Ill offer 2 kits one similar to what you see and another that braces up the stock arm , both weld on of exchange -
good thought, theres plenty of room thanks -
heres why Im bracin these up I cut some pivots off some bent A-arms I cut the Swaybar mount off the crossmember it was in the way, Ill bench make all the parts and weld them up on the parts already on the car, -
2wd to 4wd conversion. Is it possible?
Scott in Bellingham replied to sumoco's topic in Subaru Retrofitting
I have a complete EA81 Wagon up in Bellingham WA , has all the parts you need, -
well I took a few weeks off the car, time to get back on it figurin out the front A-arm braces and 3rd pivot -
I am looking for more power down low below 1000 RPM
we do here in the PNW like at walker valley driving over ans around obsticles -
how turtle comin along? I have some ideas on the movin wheel ahead for clearence
NOS, now that's interesting, don't know anything about that, -
I know that will work, but why not ask and see what is possible -
I understands its not THE best choice for low RPM Tork but its what Im going to stick with, and yes if theres any gain in lowend power then it is worth the effort , if I cam make a few simple adjustments or additions to accomplish this then Im all for it, ok Its a bone stock SOHC the one that came in the car its a 90 EJ22 , so how would I do this? , move a tooth on the belt? or somekind off slotted adjustable cam? -
how would I go about doing that? seems like you would want to retard the spark for low RPMS like on my Model T -
got my Wheeler going, its runnin a stock EJ22 stock everything, noticed then when wheelin most the slow going is like 100 rpms, is there anyway to get more power down in them low RPMs? maybe somethin with the electronics? I know I can install the Delta cams which ive done on past wheelers , if electrons make a difference would be cool to have a switch on the dash to make the change, any thoughts?
painted the bumper gloss black, it was so moist out it looks more like satin black, been looking for some rear tires cant find any decent 33s used so looks like 2 new ones are in order -
well we got another rad in there , Its raining cats and Dogs here so onto the side shields, this came off a Dodge Dakota rear of Cab all installed with my Helper
Innovative keepit up! what rear axle will you run? what body will you run?
- 116 replies
EJ Swap Harness Grounds
Scott in Bellingham replied to Scott in Bellingham's topic in Subaru Retrofitting
was wonderin about that -
.This wiring thing confuses the hell out of me , AND I am pretty sure I already messed up the harness I have because of the wrong pinouts. let me fix it,
Im thinning down a 98 EJ22 harness auto question is , after thinning can I use the grounds on the engine and not ground the harness? and if not which grounds, wire colors would be the ones to hook into for grounds on the harness thanks Guys
beat up subarus
Scott in Bellingham replied to Uberoo's topic in Historic Subaru Forum: 50's thru 70's
'form follows function', look at the original WW2 Jeep, it was put together to meet a set criteria setup by the war board, looks or style was not part of it, Im against makin something or adding something unless its real and has a function, Myself I wouldnt add stuff for looks, it need to have a purpose behind it, make a list of practical things you want in a vehicle them build around that, if your looking for style or a certain look good luck, that's what Hollywood does , make it real and it will look cool, and the bottomline is it has to preform and not be a Poser -
4.444 x 1.592 x 3.545 = ~25:1
Scott in Bellingham replied to Numbchux's topic in Subaru Retrofitting
27-9 tires go with a EJ with the Low Tork Delta Cams its less work for similar results with the stock 3.9DR
