Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. if there was such a product I would be interested in building and selling it at my store, my brother sets up and programs programmable controlers for industry, if we could get all off the shelves parts that would be a plus, are you thinking of using all the stock Subaru sensors and FI parts or ? , are the plug ends available to plug into the stock parts?
  2. Im interested in a stand alone system for doing EJ swaps, all brand new so a guy that putting a EJ 2.2 or similar in a old EA car can just do it with the engine nad wont have to have the doner harness thinned out
  3. is that a ea82 rear setup? I assumed your car was all EJ parts
  4. axles , Ive been thinkinn on this , most of the time they are strong enuf , its just that say %5 of the time we stress them past there limit, now if the axles had some give or flex say like rubber, or some slip like a clutch they wouldn't break cause they would never be stressed to that point, they do sell Sheer type axles for the VW based buggies were the sheer bolts break and you replace them quickly, but I don't think that's the answer, something with give at the point just before axle breakage , not sure the solution but know direction to go ,
  5. I like it, you see any disadvantage being so short? every get in a spot that you wished it had a longer wheelbase?
  6. its not only Subarus, you will find many a questionable builds on all types of vehicles, ever heard of a "Suicide frontend" on a hotrod? well theres a reason they call it that, people have been modifiying cars for there own purpose even before the first Model T Ford came off the line, how bout the Ford Pinto? they knew from there own tests that it may catch on fire and kill the occupants if rearended just right but out of greed they looked the other way knowing they were going to make a bundle o money and just pay out a few lawsuits, myself I enjoy seeing others creativity and myself enjoy making things and trying them out to see how they work, beleive me Ive made some junk along the way , If I never made a few mistakes I never would of learned on my own whats good and works well and what just wont cut it, the strut thing is the right Idea just needs some refining, maybe if we work together we united can come up with a great safe solution
  7. Thank You for your input,the new kit has evolved from the first few, sorry you had trouble with something I made,I had ran that kit on my own personal car for 1-1/2 years without a issue, then sold the car and the new owner had the same issue you had, I took that into consideration along with other improvement to come up with what I offer today its here if you want to view it http://www.sjrlift.com/index.php/catalog/lift-kits/0-6-lift-kit-ej-fits-90-99-detail this guy 'Subie57' just got the new kit and started a build thread on his 95 Impreza here http://www.ultimatesubaru.org/forum/topic/138102-lifting-my-95-impreza/ give him a while to post much as he just got going on it, Scott Owner and builder SJR lift
  8. is the original post guy still around? or did he get scared off?, a 9" lift is feasible if constructed properly, I have one on one of my rigs with a Truck rearend , good combo, you will want either more power or lower gears if your tires get to tall
  9. I like the bumper and its cool how the winch is hidden, wheres your gas tank?
  10. I vote Walker , set up a couple runs , one for starter rigs one for more extreme wheelin , also setup some compitition with trinket awards
  11. what cha runnin for the rear diff? open locked, lsd? and axle issues yet?
  12. what do you want in the end? the EJ22 is the superior engine Legacy brakes are way better for stopping bigger tires at high speeds the EA82 dual range is the best for low gears and a true 4wd with neither car has the loyale will need a older dualrange for offroad and larger tires
  13. little update, took this thing out a year ago , it has super low rear gears,goes good I like the rear flopper , well I changed out now I can run all same tires, I sold the yota front axle as it wasnt going to be easy ettin it all set up, also that dana 20 t-case howls leaks anf grunts so that things out and looks like Ill put a nissan case in there as it lines up well with the subbie diff, we will see
  14. went with a 2.5 , and yes thanks Austin its alive , heard it run this afternoon
  15. any others? Im lookin to update my red sedan, probably with the nissan case cause I got one and its a center shaft to fit the front
  16. I ran some aftermarket rims , same ones on Trons car, they had a little more offset
  17. I make them http://www.sjrlift.com/index.php/catalog/bumpers/ea82-front-bumper-detail
  18. Id like to see the Improvments so I can Improve those parts,
  19. there is also a dual range newer series that has been showing up here in the states the used jdm engines and trans guys have the at times , ratty2austin has one others also , if you want a 4" lift go 4" the 2 is all suspaension lift, the 4" is a 3" body lift
  20. I sell the parts at www.sjrlift.com
