5
Everything posted by Scott in Bellingham
Front end lift on accel
Scott in Bellingham replied to Speedwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check your frontend alignment sounds like its toed in -
I built this car a year and a half ago or maybe longer , its a 85 or 86 GL has a EJ2.2 and a 3.9 Dualrange ,ran it as my DD for a year, its been sitting, well its getting a bigger lift, it has a 6" on it now Im going to do a 9" or maybe a 9-1/8" will be selling the 6" ounce its off, will be installing a toyota rear axle with a lockrite locker, plan to make a bolt-on kit to install a straight axle in the ea series cars , also it will get my first tube bumper that Im designing it will be a double tube with recovery points and a ATV winch mount, probably run 31" tires or maybe the 32s I have
How many of you will bring off roaders to WCSS this year?
Scott in Bellingham replied to ezapar's topic in Off Road
if I go Id like to go out to your place -
been to long I plan to go to walker valley in a few weeks if you got experiance and a good rig your welcome to join or a truck
3/8 nc
lets see some pics
solid axle tech?
Scott in Bellingham replied to Uberoo's topic in Non Soob Cars and Bikes Discussion
I dont know the differences the older toyotas and nissans are narrower then the new ones, with 31" tires all will work well, subaru diffs are 3.7, 3.9, 4.11, 4.44 so just get one that matches your front ratio, 4.11 would be easy to match good luck you will be glad you made the upgrade, no more axle issues -
SJR 2012 ** group buy**
Scott in Bellingham replied to Scott in Bellingham's topic in Products for your Subaru
group buy is now closed thanks everyone -
shipping #130 today thank you -
W series Toyota trans adaptors
Scott in Bellingham replied to bill hincher's topic in Subaru Transplants
when one of these adapters comes up used for sale Im interested -
got it Ill send out a discouted invoice with no shippin=ng for local pickup also sent off 2 more today #133 #137 -
so keep the crank and drivers side cam in stock position, turn the passenger side cam sprocket 180 and maybe shuffle the spark plug wires around and run a carb or get 2 squirters to work at once , sounds quite simple and doable, so with the stock firing order 1-3-2-4, what 2 would fire together with the cam turned 180 ?
go to my site and make the order Ill keep this open till I ship everything -
I was talkin to a old dirt track racer the other day, says he remembers a v-8 set up so it would run like a big 4, so 2 cylinders would fire at the same time, Ive been thinkin of trying it on a EJ I got a 2.5 and a 2.2, so I have a few Qs with the stock coil pack 2 plugs fire at once? correct? also if I turned one cam 180 off to get the valves to work together what would the computer do? maybe I could ditch 2 injecter wire leads and run 2 injecters off 1 lead to get 2 to inject at the same time , lookin at the crank which would fire at the same time ?, what is the stock firing order anyway? so you ECU experts can it be done and if so needs to be done as faf as wiring and sensors and such? if it works seems like for offroad this would give more power at low RPMs
shipping today UPS -
update #132 ready for local pickup #133 almost still need to grab the wires #135 not yet #130 and #137 cancelled unless you cotact me with a payment anyone else? -
Ive never modified the linkage, will just need a short s shaped piece of flatbar with 2 holes in it to drop it down a bit,' , I free the ends of the brakelines on the body and alow them to be droped,
ok Im going to close this group buy mid next week ,will be sending out all the parts by then -
PM sent kits are 90% done, will send out soon
