Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. Skylar 4" kit EA82 shortysayhi ej/ea adapter plate Dj7291993 ej/ea adapter plate LiftedLegacy 4" or 6" EJ lift kit for a '91 Legacy and an adapter plate heres 5 if everyones commited Ill do it, whos ready?
  2. in this pic below you can see the 2 parts sitting together how they mount, it add bracing to that arm mount
  3. heres a few, click one one to go to set P1050463 P1050458 P1050453 P1050452 P1050447
  4. 10% off most lift kits 30% off EJ- EA engine Adapter plate state what parts you want and I'll tell you the price, I'll need 5 solid orders to make this happen , Ill need all payments in and all orders will be filled at the same time ,as time goes on Ill give more details heres my site www.sjrlift.com , happy shopping
  5. front engine crossmember and strut tops, 10mm x 1.25 thread radius rod/tranny mount 12mm x 1.25 Thread x 30 long rear shock bolts top on body 12mm x 1.25 T x 30 long rear diff 12mm mustache bar to body 10mm x 1.25 x 30
  6. good well talk tomarrrow the 3dr is alive again good power love the new moter ( thanks Zap) was checkin it out and forgot it has a OPEN diff so the oils drainin and Ill weld it up in the morning this time on the car , see ya tomorrow
  7. Just heard it run, this should be a good muddy run , jeff still have that red 3dr ? I could use the doors and other parts
  8. are the older say 90-93 cam the same as far as the lode size and shape as a roller rocker cam, the reason I ask is I have a set of delta low torque cams Im putting in a engine that looks like this, the only difference I saw was the RR cams have a couple narrrower lodes
  9. Ill be there , puttin a new delta camed EJ into the white 3dr coupe, its been sitting since last summer with a BHG
  10. My daughter outgrew the stock PW so doin a few mods Specs 85 Honda ATC 110 engine , rear axle and hubs 1x1-.065 tubing 145/70-6 tires, (the rear ones just for mockup) 1" round tubing for rollbars, CB radio building this for the kids but its big enuff daddy can drive it , plan on building 2
  11. I can ship you one right now www.sjrlift.com
  12. np dicsounts unless 3 kits are sold all together, come on over
  13. to add a Dual range you will need a engine adapter . redrilled flywheel, a custom tranny crossmember and a lengthened driveline , that would get you started
  14. 87 DL FWD chrome gearshift knob EJ with a carb CB radio thats all http://s444.photobucket.com/albums/q...11-5-11154.mp4
  15. not sure Ive had no reports of premature wear
