Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. I was refering to mustache bar, yes I do have a A-arm cross tube that would be $60 its in good shape just surface rust 2 or 4 wheel drive?
  2. pics had a red doner wagon so the front clip got welded on got the Allied Armament bumper from my brothers blue car, will be adding the rear trunk back on but dovetailed with tubing , then sliders and externel cage , got a toyota front axle that will come later after I beat this baby a bit,
  3. we dont have rust on the west coast like you do, its good shape some surface rust black factory paint
  4. IVE DONE IT ITS A LINCOLN LOCKER AND YOU CAN BUY THE WHOLE SETUP FROM ME AS IVE MOVED ON TO OTHER PROJECTS Also I installed a Nissan 720 4x4 pickup front Diff , axles and Hubs,in the rear, the diff bolts right in with no mods to car mounts or driveline, I had to cut off the bearing end of the stock soobbie swingarm and weld up mounts for the truck knuckle , so now I have 4.38s in the rear, so Im running 30" tires ( wore 31 x 10.50s) on the front and 33" tires on the rear , also the diffs welded up so now I have a stronger rear axle set up and unlocking rear hubs for onroad use
  5. I can do that might try this. this diff is in the front of a t-cases rig, so if the axle slines match I would prefer this should with my lift its only 1 inch over stock flex and the shaft still has play
  6. OK I want to run 4.44 gears in a open rear stub shaft diff , I have a complete unit its the newer style with female holes, I want to run it with the older stub shafts how can i do this? I have a bunch of diffs some old stlye and some new what parts will make it work thanks ?
  7. puttin the engine back up front got the engine back up front in stock location, hereswhere it used to live transfercase in position anyone know what all this means? just bought a set of Yota axles they both have 5.29s, front has a ARB air locker and rear has a lockrite
  8. good times , night run was awesome should do another pics and video later
  9. this auction is now ended , If you both want one Private message me your info and you can have it for $100 plus shipping
  10. this weekend Ill b e at walker offroadin
  11. whose goin Friday and what time you goin? Jeff you got Friday off?
  12. almost there yes those are 33s on the back with unlocking hubs
  13. EJ adapter plate to install EJ 2.2 or EJ 2.5 into the older cars First bid starts at $80.00 , min bid at $2.00 increments after the starting of $80, this will be like a live auction, when the bids wain I will call a going once , going twice , gone and highest bidder at that time will buy it, I can take Paypal or check or GOLD , shipping will be $20.00 ,to make a bid post a reply here with your bid and good luck . Scott
  14. Dicey I have the hatch and the ball joint, no front axle
  15. added some paint and some rear bump stops to my 5 door coupe wheeler will be just me on friday , what time you goin on friday?
  16. Jeff you guuna glab that parts car from me in the next few days?
  17. I have 2 sets both installed easy but the engine was on the bench, leave head on remove the rockers and slip in the reground cams, for a Offraod wheeler I would run them , I never check gas mileage , EJ with the cams and a dualrange is awesome , especilly compared to a stock EA82 1.8
