Scott in Bellingham
Everything posted by Scott in Bellingham
  1. first real snow of the year for us post up your winter pics (Limit them )with your Snowburu Red wheeeler sedan mid engine , New GL coupe with 6" lift and Bighorns
  2. $100 to redrill a EJ flywheel you provide
  3. 27" maybe 28 would be the largest you could get with the stock struts , maybe some aftermarket adjustable struts would give you more room
  4. Ken what set up would you recomend for a 22R for off road? Scott
  5. I can redrill your "EJ" flywheel to bolt to to EA82.
  6. Impreza flywheel is larger diameter then EA82 , you will need the imp fly to engage the starter
  7. no go , the adapter will make it 1" off in length
  8. OK looked at the 80, didnt get, went and bought a 82' it has a 22r and a 5 speed this ones all stock, with 30s , Paid $700 is has been sitting and has oil in the rad water and needs a alt , does run and drive everythings there and works, will be parting out the body and bed, cabs in great shape beds got rust
  9. maybe a car trade , will see it today, its lifted on 33s
  10. shorten wheelbase , plop a Justy body on, run 33s , lockers, flex
  11. wheeler , things dont rust over here on the west coast
  12. Looking at a 80 4x4 Toyota pickup it has a 20r , anything I should know about this truck? what years are what , are the old ones the same as the new ones? as far as axle and drivetrain strength ? and interchangability ? EDIT**** bought a 82 it has a 5 speed with a 22R carbed
  13. is it the same part as a passenger side if so I have a used one $60
  14. rear diff support bar will need holes drilled in the body, , I used long bolts up into the floor with large washers, also driveline center bearing will need a mount , I welded up a bracket with 2 bolts
  15. came across this picture , anyone have knowledge of this thing?
  16. I need to see some detailed pics of your buggy , Thanks Scott
  17. Ive been running and seen flopped lug nuts on flat holes for years
  18. place that deals in machine shop supplies, http://www.grizzly.com/products/Bevel-Cutter-1-2-x-60-/H2966 H2966 Bevel Cutter 1/2" x 60° .productThumbnail { width: 32px; height: 32px; border: 1px solid #999999; text-align: center; } .productThumbnail table { width: 32px; height: 32px; } .productThumbnail table td { text-align: center; } table.productImageGrid { margin: 0px 15px 15px 0px; background-color: #FFFFFF; text-align: center; }
  19. go here www.sjrlift.com and make the order , group buy is closed, so regular price
  20. Eric and I will meet up at Jack in the Box at 8:20 in Bellingham then off to Joes in Mt vernon at 9 , Ive been getting my car ready , dropped in a HEMI with twin Turbos, installed a chrome plated gearshift knob, oh yeh and a set of neon running light under the car, and a set of Hi-Jacker rear shocks with a Chrome rear diff cover, and a new set of 44s, ...............:-\...:banana:.zzz zzz should go pretty good, would like to find a deep Mud hole to play in, will be on channel 44 on th ole CB
  21. I need some direction on the exhaust, I would like to make my own header, if so what should the pipe diameters be and what should the lengths be, also I would like to use the stock y pipe head flanges up untill they turn into pipe, so keep the y at the head, or should I do 4 individual pipes?? , my 2.2 is a dual port, thanks,
