Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. I would like to make a bunch of Subaru based buggies , basically take one Doner car a EA81 or EA82 , make a light steel framework of tubing, add all the Stock subaru components , add some fiberglass panels and or steel or aluminum panels, we could use my shop , if I had say 3-5 guys that could dedicate 1 or 2 nights a week we could design and build them in a batch , would need money up front to buy all the supplies, you provide your own Doner car, my personal favorite would be a EA82 with dual range and add a EJ22 something like these, that you guys think? anyone in NW WA that would be interested ?
  2. what is this company I would like a set what is the reduction on these lowwer hi/low gears how much Money do we need?
  3. one question: can I build a EA82 Dual range 5speed with either the 4.11 or 4.44 final gear? , and if so what parts are needed?
  4. Heres the nissan 720 pickup front setup the diff bolts right in , will need to get one more long axle , this will go in the rear
  5. could you figure out the wiring diagram and bring it next time, so we could just identify wires and hook it up , thanks
  6. todays progress with some great help from a couple o board members old EA82 Carbed engine and burnt Auto trans out, 3.9 Dual Range installed EJ 2.2 installed with Delta Torque Cams ( cams installed today, and found woodruff key keyway and pulley and timing gear shot, keyways damaged, got it welded up and ground and good parts installed alll today) 6" lift blocks mounted on engine crossmember, and radius/tranny crosssmember
  7. here it is jig weldin up the rear Hammerite Grey paint
  8. it will physically bolt right in , looks like 4.3 to 1 ratio , so rear tires will be bigger then front
  9. the car is white at the moment, been lookin on line for some ideas
  10. Update going with a 6" lift, got most of it built tonight the 2.5 fell threw so Im going with a EJ22 got a set of Torque grind Delta Cams for it, looks like Saturday we will start into the car, thinkins a Red White and Blue paint job is in order
  11. never had one , not aginst it, would like to know the specs , as long as its a stand alone unit that can play and burn DVDS and can exchange files with my PC , Picture softwere would be nice internet access would be cool too
  12. Laptop computer I can burn and play DVDs on Early ford escort distributer , coil and ignition wiring EA82 4wd flywheels Dual Core EA82 Radiator
  13. Thanks for showin us ther trails heres a couple pics http://www.ultimatesubaru.org/forum/showthread.php?p=949641#post949641
  14. Friday evening a few of us went out to Liberty http://www.ultimatesubaru.org/forum/showthread.php?t=114835
  15. is there a place to wash off your car, say after the mud pit?
  16. Ive done trades for parts , I have the plate and flywheel
  17. you can always ride with someone,
  18. sold a car so Im ready to build up another The culpret: I picked up a 86 GL 3DR white Coupe, its a Automatic with a Carbed EA82 1.8 the plan junk the engine and tranny add EJ 2.5 with dual cam heads , all stock wiring and ECU from a 98 Leg Weg add 3.9 Dual Range going with a big lift on this one maybe 6" maybe taller 7 or 8 30-31" tall Mud Terrains Nissan 720 truck front Diff, axles and hubs will replace the rear diff and axles and Hubs , this will give me a stronger rearend and axles and the diff will bolt right in using the stock diff hanger and stock Soobie driveline , also with the rear diff weled I will be able to unlock the rear hubs using the Nissan 720 hubs which also are 6 bolt so I will drill the front hubs to match, this car will become my daily driver and have the EJ 2.5 power to pull a trailer and have some bigger rear discs to stop it, will start the build first with building and installing the lift and pullin the engine and trans, will have Adam at Norhtwest Rally Sports in Bellingham WA wire up the monster engine , Huummmm should I get some Delta cams while Im at it? HhHHhhhhmmmmmmm may be a while before this all starts but Im just excited and wanted to share , been talkin to Adam for a while about the engine, Ive never had a 2.5 befor
  19. we may come over Thursday , so maybe friday would be a good day, or saturday morning
  20. will this be a " one off " or do you plan on building and selling more?
