Everything posted by Scott in Bellingham
Honda Wheeler
look what I pulled out of the bushes Honda AN600 I had some atv tires on it years ago, went good till I broke the tranny gears, just part of the clean up Im doin
NWWO and OFFROO'D Mid Summer Run Walker Valley ORV Park July 16-18
I dont even know seems to change week to week
Forester same as Legacy underneath??
rear suspension has a different arm setup at least on the legacy anyway , front seems to be the same
specs may change just show up if you want to see:popcorn:zzz:headbang:
I make lift kits for legacy and impreza up to 99 , now will that kit fit a Forester, is it all the same underneath just with longer struts??
Nw wa offroad
sounds like we need to go wheelin
Car Stolen... Seattle Area
the local yards here will take less then 1/2 a car body , so if its cut up they will take the parts, probably not in one load tho
offset block question
I can send you a paper pattern if you like that would be correct angle , it will require clearence of the body either by cut and bash or small diameter strut springs , or I can make you a set of extensions
Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!
I am hoping someone has a cheaper driveshaft makin' shop in mind? Driveline Services in Bellingham way cheeper, you bring him the driveline he will make it the length you want
legacy to loyale susp. swap?
loyale and legacy 2 different animals, if you do add longer rear shocks make sure you drop the diff also
Yo Da Man Jeff Thanks
Red Sedan Build , solid rear axle
Oh Yah those are trail rated, maybe wedsday evening stop by
its a roller again !!!!! got the details figured out,still need some more fabbing done
Walker Valley Time
Walker is hard the the subbies, will need lift , tires and a locked rearend Huummm thats to bad , glad you have work tho Awesome are you ready for body damage?
Walker Valley Time
car seems to run ok, no oil leaks and hasnt needed water thanks guys
Walker Valley Time
that would be nice
Imthere whats the skinny on campin?
Walker Valley Time
got a new used engine in the 3 door so Im ready for a Walker valley outin, a friday or a Saturday any takers?
Northwest folks.
Bellinghammer WA
Do you guys drill your own wheels?
heres a pic, I have the same pattern already redrilled if you want them $90 for the set of 4 , wheel pictured is not mine
EJ gen1 and gen2 Lift Kit $485 NOW built by Robots
same one, you have the only one like it #1 robot built, start a build thread in the offroad section so we can watch your progress
that made me Laugh :lol:
If you want one go here www.sjrlift.com and make the order , please specify what length you want the strut extensions , there has already been some interest so make your order before the price goes up Scott
Did a little impromptu wheelin tonight...
call that Fun sounds like alot of work ahead of you , Yes this is why people move onto other vehicle choices, on the Isuzu axle you can just run smaller tires up front to make up for the ratio difference, Ill help with the math if needed ,with a 4.10 rear and a 2.9 front if you ran 31s on the rear you would run 29.5 on the front, or 32.6 on the rear with 31s on the front, or 33s on the rear with 31.4 on the front , you can get it close enough for a wheeler , even running some new and some wore out tires you can come up with a combo that will work, if your spinnin most the time it will work just fine , see ya in July at the Walker axle breakin Run
I have redesigned the 90-99 EJ Lift, all 3" blocks except struts can be 2" or 3" you decide ,its all built by robots now so Im going to offer 5 kits for $485.00 each, this is all new only 1 out there now , after these 5 are sold the regular price will be $600 a kit tell your buddies on the other forums as this is the only spot it will be mentioned , if you buy 2 kits and both are sent to same address and paid with one payment then Ill sell them for $450 a kit , reply here if your interested WA sales will also require sales tax and of course theres shipping, Im excited about this new kit, Ive made 6 by hand now and its to labor intensive so now with this kit the robots get the job Scott with SJRLIFT
