5
Everything posted by Scott in Bellingham
Screw in studs for traversing occasional ice
Scott in Bellingham replied to blk99obs's topic in Off Road
your best deal is a good set of snow tires with studs , Mud tires don't do well on ice -
they use them on atvs http://i8.photobucket.com/albums/a13/khendriksma1/ATV/Tires/PICT00682.jpg -
at slow speeds a screw in tire stud screw will help, you need enuf rubber so you don't drill into far and loose tire pressure http://www.arcticchat.com/forum/attachments/atv-tires-wheels/166929d1233892770-tire-studs-atvstuds.jpg -
I run a rear welded locked diff in many of my offroad cars, a couple keys to this is keep the rear light don't overload your trunk run good pressure in those tires and I don't drop a axle as its a hassle at the trailhead to reinstall and the smoother the tread the better, also its more squirrely in wet cornering
http://www.sjrlift.com/images/stories/virtuemart/product/bumper%20ea82%20front%20sjr.jpg http://www.sjrlift.com/images/stories/virtuemart/product/bumper%20ea82%20corner%20sjr.jpg
push button vs. dual range flywheel
Scott in Bellingham replied to andrsn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can redrill that for you http://www.sjrlift.com/index.php/catalog/engine-swap-parts/ea-ej-swap-redrill-flywheel-machine-work-only-detail -
Ground the harness to the engine, should be black wires, power + to the main brown relay
- 3 replies
- Engine swap
- Ecu wiring
(and 4 more)
Tagged with:
NW Washington Offroad group or Hill Holder Offraod
Scott in Bellingham replied to one eye's topic in Off Road
We go out every month or so at Walker Valley near Mt Vernon -
'16' SJR Wheeler T-cased and Yota IFS
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
got the car, whats the best way to lock the center diff as Ill be getting the power out the rear shaft ? -
Thanks I looked over that yota tread good stuff, I might do this In stages, I'm pickin up the car this week, it's a automatic, think ill do a quick 8-9" lift figure out the t-case mount get it drivable then look at swapping the axles out, that way I'll have a drivable car instead or a long drawn out project takin up room -
EA81 4speed swapped into EA82 loyale?
Scott in Bellingham replied to Rnasty's topic in Subaru Retrofitting
You'll need to stick with a EA82 clutch pedal assembly , the ea81 has a different trans mount so you'll need to make a custom trans crossmember, the legacy trans won't bolt up, and find a longer driveline if it was me I'd wait till I found a Dualrange ea82 trans -
Found a car a 92 legacy wagon, should pickup this week it's a automatic, still not sure direction will be going with a devorced transfer case , I have a samurai and a 720 Nissan case to choose from not sure the best, I know the Sammy has a lot of aftermarket gears parts available , -
need an ej22 loom cut down for a brumby
Scott in Bellingham replied to brmbyboy's topic in Subaru Retrofitting
if you were closer I do these but Im in the USA -
EA81 rear differential
Scott in Bellingham replied to pksjeep's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sure will 3.9 for non turbo -
EJ20 Carb and ignition conversion
Scott in Bellingham replied to hectorshouse46's topic in Subaru Transplants
Sure can I'll look into what distys work -
Struts on loyale
Scott in Bellingham replied to Dpmason89's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Loyale has struts on front and shocks with swing arms rear you can get a 1" or so with struts on front, would need a complete lift kit for much higher I sell them here www.sjrlift.com. The EA82 kits fit your car -
NW Washington USA the 2 bolt cover is removed and replaced with the ditsy, it exposes the end of the cam -
the Escort parts needed are the complete disty, the plug from disty to ignition module, the I module, a normal coil and coil wire -
Early 80s modified ford escort ditsy, I can modify it for you, also I sell a weber adapter , the stock EJ manifold is machined and the adapter welded on, can do both for you -
http://board.marlincrawler.com/index.php?PHPSESSID=74c26eacf3a7f6051650ba24921741c6&action=dlattach;topic=101063.0;attach=148384;image too cool!!
