Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. can I run a EJ engine with the SPFI parts off a EA82 ? , I know I would have to get the distributer spinning off the cam shaft, would it work, anyone done it? thanks
  2. Have a EA82 with a weber, can I make it run without the ECU trying to simplify the wiring
  3. Imin the process , just have nothing to show yet, I really got to many things going , if you have a cad drawing I can make you one
  4. Ive pulled them stock hold down right off the car, they are designed for downward pull not forward,
  5. 5" front 4" rear 27" Swampers
  6. all loaded up headin out, will stop by Joes , then Jeffs then walker
  7. Ok check this out all subaru parts, justy engine, justy trans acts as a 4:1 ratio transfercase
  8. Iveseen and heard the car for a year now almost daily, he did change back Oil and the noise is still there
  9. a friend of mine has this car a 96 2.2 outback, no noise then he did a oil change with 20-50W oil then the lifters started to tick, how can I fix this? I plan on installing Delta cams and want to fix the tick while Im at it Scott
  10. look what I pulled out of the bushes Honda AN600 I had some atv tires on it years ago, went good till I broke the tranny gears, just part of the clean up Im doin
  11. do you want the wheels if so tell me , may go next week
  12. rear suspension has a different arm setup at least on the legacy anyway , front seems to be the same
  13. specs may change just show up if you want to see:popcorn:zzz:headbang:
  14. I make lift kits for legacy and impreza up to 99 , now will that kit fit a Forester, is it all the same underneath just with longer struts??
  15. sounds like we need to go wheelin
