Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. the local yards here will take less then 1/2 a car body , so if its cut up they will take the parts, probably not in one load tho
  2. I can send you a paper pattern if you like that would be correct angle , it will require clearence of the body either by cut and bash or small diameter strut springs , or I can make you a set of extensions
  3. I am hoping someone has a cheaper driveshaft makin' shop in mind? Driveline Services in Bellingham way cheeper, you bring him the driveline he will make it the length you want
  4. loyale and legacy 2 different animals, if you do add longer rear shocks make sure you drop the diff also
  5. Oh Yah those are trail rated, maybe wedsday evening stop by
  6. its a roller again !!!!! got the details figured out,still need some more fabbing done
  7. Walker is hard the the subbies, will need lift , tires and a locked rearend Huummm thats to bad , glad you have work tho Awesome are you ready for body damage?
  8. car seems to run ok, no oil leaks and hasnt needed water thanks guys
  9. got a new used engine in the 3 door so Im ready for a Walker valley outin, a friday or a Saturday any takers?
  10. heres a pic, I have the same pattern already redrilled if you want them $90 for the set of 4 , wheel pictured is not mine
  11. same one, you have the only one like it #1 robot built, start a build thread in the offroad section so we can watch your progress
  12. If you want one go here www.sjrlift.com and make the order , please specify what length you want the strut extensions , there has already been some interest so make your order before the price goes up Scott
  13. call that Fun sounds like alot of work ahead of you , Yes this is why people move onto other vehicle choices, on the Isuzu axle you can just run smaller tires up front to make up for the ratio difference, Ill help with the math if needed ,with a 4.10 rear and a 2.9 front if you ran 31s on the rear you would run 29.5 on the front, or 32.6 on the rear with 31s on the front, or 33s on the rear with 31.4 on the front , you can get it close enough for a wheeler , even running some new and some wore out tires you can come up with a combo that will work, if your spinnin most the time it will work just fine , see ya in July at the Walker axle breakin Run
  14. I have redesigned the 90-99 EJ Lift, all 3" blocks except struts can be 2" or 3" you decide ,its all built by robots now so Im going to offer 5 kits for $485.00 each, this is all new only 1 out there now , after these 5 are sold the regular price will be $600 a kit tell your buddies on the other forums as this is the only spot it will be mentioned , if you buy 2 kits and both are sent to same address and paid with one payment then Ill sell them for $450 a kit , reply here if your interested WA sales will also require sales tax and of course theres shipping, Im excited about this new kit, Ive made 6 by hand now and its to labor intensive so now with this kit the robots get the job Scott with SJRLIFT
  15. some progress on er 8" lift all done up front took the sawzall to the front and rear, decided to stick with the toyota rearend ditched the 720 Nissan case , got another plan, gas tanks gone should have good approach and deparcher angles:grin: lookin at diff ratio options, if I use my 3.7 LSD up front , with the 410 toy rear I could run 30 in tires on the front with 33s on the rear, a Air locker in the rear would be nice:eek: this thing should be pretty light when In done, will leave the red paint and maybe add some "Invassion stars" on the doors like this hood one
  16. Guess what Jeff, I saved it from mother nature shes back in the shop, I couldnt give up on er, so again I have way to many projects going , lets see Justy Monster Red car ( AKA Shotgun Wheeler ) White 5 door wheeler Robs car ( decided its a keeper just needs a huge lift)
