5
Everything posted by Scott in Bellingham
right here in B-ham on craigs list $300 got a good strong moter
goin to lift her. .... startin tomarrow if you would like to help 23 Jan 2010 its a 1.8 SPFI 2 wheel drive DL will be installing a dual range , rear axle setup with welded diff and addin lift will be runnin 235/75-15 MTs on yota rims 5" lift front 4" lift rear, the car has the usual stringy dog hairs, pushed in front bumper and hood thats bent fronm flying up while drivin
5" doing it tomarrow if anyone wants to come by and lend a hand ..... anyone?
Ill be there, got some wprk to do first
Paint Job
Scott in Bellingham replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I hear ya you can do it yourself get some Omni single coat and a cheep harbor freight gun and borrow a air compressor ,Ive done one out under the trees and it came out good, also people have had good luck with these small foam throw away rollers , go with a light color it will hide most the flaws -
official build thread.........this is monstaru2
Scott in Bellingham replied to monstaru's topic in Members Rides
what I dont see anything!! -
Nissan / datsun rear diff, same as Nissan 720 4x4 pickup front diff, bolts right up no mods, would need to make own bearing carriors
remember hes got a tranny in that bike engine so 2 trannys i with low range AWesome!!!
Jeff if I come can I drop off BIlls engine just befor at your place?
Let's see your LIFTED Soob off roader 2010 edition.
Scott in Bellingham replied to ezapar's topic in Off Road
87 soooobie my origanal 6" lift with 27" swampers An Idea as how to mae it lighter with better aproach and departure angles -
SCOTT, (you're) on..........BUILD OFF 2010
Scott in Bellingham replied to monstaru's topic in Off Road
Brian this is what I plan to build licensed and legal to drive on the road, Subaru body, Subaru Engine, also whats all this about? """Itsignifiesourdeterminationtonotstrikethefirst blow,butalsotonotstandmuteandallowour lovedones,andallthatwebelieveinandstand for, tobetrampledbymenwhowoulddepriveusofour God-given–ornatural,ifyouwill–rightstosuit theirownends. """" -
Red Sedan Build , solid rear axle
Scott in Bellingham replied to Scott in Bellingham's topic in Members Rides
I got one its deeper then the toyota, and positions the starter back farther, maybe would work with a automatic starter not sure -
have a nissan case I may sell
my birthday comin up
tig -
yes and yes -
Heres the EJ Flywheel heres the EJ trannywill need to cut the front off the tranny machine it down , cut the Toyota Bell housing in half Machine it down and weld the 2 halves together -
OK decided which direction to go, I didnt really like the Nissan case its so tall and would need a framework to mount up , so I went out and picked up a Toyota 86 4runner 4x4 tranny with transfercase , checked it out tonight Heres the Subaru clutch disc next to the Toyota one, the Toyota one has a bigger hole with more splines , subarus on the right, also the subby preasure plate has a larger throwout bearing and "hole" subbie center bearing slipped onto the Toyota pilot same size... -
like the loose nut holding the wheel -
Brian this gives me more motivation to get er done quick and not be distracted by other new and old projects, I must have A. D.D. or somthin -
where?
How heavy are is your Wheel and tire together?
Scott in Bellingham replied to backcountrycrui's topic in Off Road
on the roof or the back beats having it hit you in the head, Ive done that , even broke both moter mounts on that fall -
Im up to it .................... rules I would say minimum must have Subaru Engine and body any year or model , what else Brian ?? -
mount rear diff up front , normal not upside down the nissan case is a 720 from early 80s trucks , sammy case works too
