Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. EASY you dont remember that silver car that saved your ( Dodge) 2-1/2 years ago??, that thing wasnt "easy" has a 2nd tranny and transfercase , 9" lift and modified body, come on Brian Ill challenge you to a build off and we will meet up this summer and compete our 2 soobies side by side and see what happens , I realy like my ole white car just want somthin a little better that will not break
  2. OK Ixve seen all these "snorkles" now lets see them in action with your car in deep water or are they just for looks?
  3. got the car moved today, its now back it the corner all so started some major cleanup found the back wall of the shop, its been 10 years since I saw that area, moved the new to me bandsaw in place , moved the wood stove out next for a steel rack on the back wall
  4. Mick now that you have had it both ways is there anything you miss about hte old Brat before the axle swap? anything??
  5. been lookin at the car and lookin at different options, pros and cons heres a list............................................................................2nd tranfer case Lower gears,weaker front diff studs because Im using a rear Diff Higher center of gravity as the engine and transaxle would be in stock height more weight with 2nd transfercase and frame to mount it,also second crossmember for engine support and 3 drive shafts instead of 1 keep stock transaxle................. lower center gravity , better clearence mid car, less of a aproach angle , less weight, less parts, less engineering, only one driveshaft to have made not 2
  6. been designing a 8" lift for the EA cars so you can mount up a 2nd diff up front and add a transfercase, any interest? anyone want one? if so it would give me more incentive to figure out the details SJR
  7. stop by tonight if you like we could move shotgun willey
  8. it time to get back on this heres the planned revised specs 4.10 toyota rear end 4.10 subaru rear diff upfront 31" mudders would like to get some 32 x 9.50 TLS Swampers eventually, will wait till its runnin dual transfercases, stock subaru and Nissan 720 bob the rear pinch the front winch mounts front and rear transverse buggy spring in rear with tons of flex with airshock overrides engine not sure may go EA81 or carbed EJ or Atomic flux capacitor would like to have it up and going for this summer season of Walker wheelin
  9. My PC is on the fritz so I havent been on line, but thats a stock wheelbase with 6" lift and some 30" tires , if we run the Toyota rearend with the 4.10 gears we could run 31" tires in the rear and 29.48 tires on the front with the stock 3.9 , sorry no T-case no needed with the EJ with Delta Cams and the weight loss program
  10. I wont be there , but you can stop by in the evening if you like maybe 6:00
  11. this is what I was thinkin :banana::banana:
  12. I do for the the gen1 Legacy (90-93?) ,also have the front and rear strut tower parts to weld up your own towers , may be same I dont know SJR
  13. Blocks placed between all suspension parts and body, so you could call it a body lift, will drop the engine crossmember for more engine room SJR
  14. push buttons fine unless you go with big tires say over 25-26" and want to do hill climbs
  15. Damage John got a hot clutch, I almost ran out of gas , the low light was on
  16. good times lots of Fog but no snow, made my goal was to make it to the pit and go sledin well no snow, had to tug on John one time and he had to push me off a rock one time so we are even
