Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. Can someone bring a Map as I dont know the roads up high thanks
  2. Ill drive threw Joes parking lot at 9 then up to walker
  3. yes I could do that , would it be 5" tall Im guessing not 3" tall
  4. 1/8" dont make it to heavy its 3" x 1/8 tube I will sell you those front brackets if you want to make your own
  5. oh I mean the stock EA82 disty or maybe some of you electronic wizards can tell me how to run them coil packs without the disty just use the sensors on the crank and cam and somehow make them coils spark without the computer
  6. Buildin up a new moter this ones a 91 EJ 2.2 going with dual single barrel 34 Webers , a VW Bug setup I got a couple years back, got the intake manifolds builtup , cut the bottoms off a stock EJ intake manifold added some tubing and the flanges off the VW Weber intakes , got a set of Delta Cams they are the torque grind , lookin to get more lowend torgue out of this bad boy, will be going into my new wheeler a EA82 3 Door Coupe white , also looking to get the stock Subaru Disty turnin on this one , I used the Escort Disty on the last engine , works good, just wanted to stick with the sooby so I wont be modifiing any wiring and also the suby disty is sealed better and self contained , goal is lowend dont care to much on the high end for a Walker wheeler , what ya think
  7. I know its a long trip from your place, hope you figure it out:eek:
  8. get Decon and set it in the car , they will find it, no easy way to get the nest , if there is no A/C you can remove the hose between the fan aand heater box if not then the dash has to come out
  9. so chux will a EA82 D/R fit into a EJ trans case?
  10. we head out to walker valley near mt vernon each month
  11. under the rear mustache bar wear it mounts to the body, drops the diff down 1"
  12. Gloyale you are correct , I would not have had room for the 31s if it was a top block
  13. and I know the 90 , 91 Legacy 5 speed have the 4.11 as I have one at my shop
  14. early gen 1 legacy 90 same housing and stub shafts
