5
Everything posted by Scott in Bellingham
I have a old 26' model T truck cowl that is pretty flat may use parts of it for the shape, I want to build something that has a high fun value and a low price, years ago I had a model A coupe and it needed everything, I figure if I start with a modern vehicle most the works already done for me and the price is right, similar to this cowl / firewall
SJR EA82 new white wagon 6" build thread 2009
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
got some more pics for ya Original engine steering shaft extended from 6-1/2 to 10-1/2 overall -
come on up this weekend:) -
thats correct, a little more room, I now have the EJ in ,now to hook up all the engine stuff, Im need to load some pics for you guys, I plan to be running within 2 weeks looks like I have my blue sedan sold so it will be a swap, -
Been thinkin on this for a couple years, looks like it may come to pass , I would like to take a mini import pickup and convert it into a little Hot Rod heres a model I threw together , it started as a stock truck and I converted it thinkin once the white car if a runner and tyhe shops all cleaned up I should start on it , already have the truck lined up to get its a 86 Dodge d-50 m( mitsubishi) has a cracked head, I have a bronco 2 V-6 I could use and a 32' Ford front rad grill and lights
you ell um Jeff we all want to see whats goin on
whose offended? what Ive found is the trail is a great teacher, people can sit back at their computer and say anything they want but get out on the trail and all the talkin and braggin end, some are up to the task both car and driver and some are not, you need both traction and power to the ground and the skills to manage the terrain , you need to know your vehicle and know what it can do and what it can not you also need to know your vehicles weaknesses and work within those tollerances so not to break, over the last 4 years Ive learned alot from the soobies Ive driven Ive also learned alot about myself, Ive made many a mistakes and have learned from them, someday it would be cool to go down under and hang with you guys and go offroadin with you. my weak spot is I tend to smash up the right front corner of my car so maybe it would help me to sit and drive on that side of the car , my preference in a soobie for offroad would be EA82 axles, EJ 2.2 , Dual range 5-speed 3.9, Welded rear diff, 27-29" swampers , now here in Washington we see some good mud, seeing your pics you probably dont need good mud tires like we do, Cheers SJR
Hard part done now for the engine swaporoo -
NW Washington Offroad Name Change?????????
Scott in Bellingham replied to one eye's topic in Off Road
in WA you can regester it it your name them after 3-4? yrs get the title
I think 'Soobie' or some reference to Subaru should be in the name Grocery Getter offroad -
Biggest size tire with ouback lift on Legacy
Scott in Bellingham replied to rweddy's topic in Off Road
27" swampers on mine -
Made some progress today finished up welding the lift parts and got the rear all lifted Heres the parts used some alloy parts I had left from my first car the red one that was 4 years ago wow!! Heres my Jig its a chunk of the old blue Bomber -
good on ea82 on the ea81 you will eat axles
Lifted Subaru Camber Question
Scott in Bellingham replied to bobs97c5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there is no adjustment to correct this . to stock you would need to drop the complete suspension, the swing arm cross tube say 3 -4 ". diff will not effect Camber just axle life SJR -
Need Help Locating Rims
Scott in Bellingham replied to kpullen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
were are you? I have free ones in NW wa -
3.9 ratio on the diffs, no gears avalible , no locker , just the LSD from a 3.7 converted to 3.9 I wouldnt go over 1" over stock on those stock axles, especally with bigger tires ,good luck and keep us posted Scott
look what ups brought . its a 4500lb atv winch cost just under $200 will be designing a double tube bumper this baby will fit in havent done much on the project, been helpin SoobieDoos car and doing a big shop yard clean up , will get all the lift parts ready first then start , been airing out the car as some mice took it over -
like to bring a subway sandwhich it always gets used
get a solid spool type , the multiplate stamped steel ones ive had issues with
Sedamn Timing belt broke
Scott in Bellingham replied to bigo1966's topic in Old Gen.: 80's GL/DL/XT/Loyales...
will not hurt it on a EA82 and early EJ -
thats what I wanted to hear
